Makes terrible noise when spinning - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 79,186 Answers
There are only two things that cause this, one is a worn out washer tub bearing, the other is worn out drum stabilizers which dampen out vibration and excessive wobble from out of balance washer loads, u will need to pull the machine apart to determine what needs to be replaces, many times both parts are ruined.
Posted on May 05, 2010
Terrible noise when washing/spin cycle. clothes are still clean but hte noise is VERYLOUD! Any idea of the cause?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Dec 05, 2010 | Westinghouse Washing Machines
My front loading washer makes aloud noise and shakes terrible when it spins at mediun or high speed. model ifw7200tw
Washer Problems Washer noise when spinning
heatman101
Nov 26, 2010 | Washing Machines
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine - terrible noise during spin cycle
sounds like the drum is rubbing on some part of an exterior wall of your washer,.or you have a bearing going, or worst case scenario you have transmission problems and need to get a serviceman in to check your machine.But firstI would call the manfacturer and explain the problem they may be able to resolve it over the phone give them model no. Make and year of manfacture they hopefully can help you with this
Jan 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
It makes a terrible groining noise on spin cycle
find out if the agitator moves on wash if not then it is most likely a motor couplier. No big deal to change. You can also just tip the washer back and look under and look between the motor and transmisson and see if the couplier is still in good condition
Nov 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Dryer doesn;t spin
Sounds like the belt has broken. The terrible noise was probably the belt slipping until it gained traction.
May 17, 2009 | Dryers
Terrible noise when agitating
Your transmission has gone out. The reason the spin cycle works is because the transmission spins two different ways and you agitate way stripped the gear. Some places rebuild them. Try with your local stores maybe they can rebuild it or get you a good used one. If not you can order a new one from sears.com
Nov 12, 2008 | Kenmore 24032\24036 Top Load Washer
TERRIBLE NOISE ON SPIN CYCLE
That is normal, after a little while all washers make that horrible noise you should be able to put up with it
Hope this helps! - Josh
Feb 03, 2008 | Frigidaire GLWS1233A Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
