Question about Garden
Riding Lawn Mower Completely Dead
I have a 50'' Huskee Supreme Yard Tractor that will not even turn over. I was towing a small weed sprayer yesterday (i.e. with a small motor pump hooked to the mower's battery), and after I stopped and shut the mower off to clean out the sprayer, the mower would not even turn over. Nothing, completely dead; no lights; no hour meter. I thought maybe the sprayer drained the battery, so I trickle charged it overnight; but tonight it still was completely dead. I double-checked all the safety switches (i.e. the seat, brake, and transmission selector; they all seemed to engaging properly). It's almost like I blew a fuse or something shorted out; I don't know. I pulled the deck off to examine some of the wiring and found one of the wiring bundles running from the engine compartment area back to under the seat had come loose from along the frame and had been worn down to expose one of the wires; it was a green wire (assume it's a ground?). Any ideas?
    President:
  • 1,851 Answers
Sounds like the battery gave out.
If the battery test good then you most likely have an inline fuse that is blown out.
Posted on May 05, 2010
What is the mixing ratio to 1 gal of water?
Their products are here, but they don't tell you the usage. It has to be on the label by law. The rear label usually lifts up to reveal a small book of three or four pages. If it isn't there, contact the company via the website.
http://www.spectracide.com/Products-and-Solutions/Lawn-Weed-Killers.aspx
The does have label details here
http://www.spectracide.com/Customer-Help/Labels-and-MSDS.aspx
For the Spectracide it is 1/2 oz to a gallon, but it depends on what type of grass you have. I will copy and paste the label details, but I doubt the format will stick, but it is all there.
Ounces of Concentrate to Use for:
St. Augustine*,
Bahia,
Centipede
2/3
2 2/3
13 1/3
21 1/3
32
32
1/2
16
250
1,000
5,000
8,000
Sq ft
to be
Treated
Bluegrass,
Fescue, Rye,
Zoysia
Gallons
of
Water
*DO NOT USE ON FLORATAM VARIETY OF ST. AUGUSTINEGRASS IN
FLORIDA.
HOW MUCH TO USE
SPOT TREATMENT
To spray small areas or individual weeds, use a pressure sprayer for better
control. Do not use a hose-end sprayer. Mix as directed in table below. Shake
well before spraying. Be certain to wet each weed.
ENTIRE LAWN
PRESSURE SPRAYERS
Measure amount of concentrate from chart below into sprayer tank and dilute
with 1 gal of water. Close tank sprayer and shake well before spraying. Use a
spray pattern that gives small spray droplets without any ne mist to treat
250 sq ft.
HOSE-END SPRAYERS
"CONCENTRATE ONLY" (DIAL) SPRAYERS
1. From the chart below, determine amount of concentrate to be applied for
each 250 sq ft of lawn.
Bermuda,
Bentgrass
St. Augustine*,
Bahia, Centipede
1/2 - oz
2 - oz
2/3 - oz
2 2/3 - oz
1 - oz
4 - oz
1/2 - oz
2/3 - oz
1 - oz
Grass
Type
Ounces in
Sprayer
250 sq ft
1,000 sq ft
250 sq ft
1,000 sq ft
250 sq ft
1,000 sq ft
Area
Treated
Dial
Setting
Bluegrass, Fescue,
Rye, Zoysia
FLORIDA.
2. Fill sprayer jar with enough concentrate to cover area to be treated. Do not
add water to sprayer.
3. Set dial on sprayer to the setting from the chart below.
4. Attach sprayer to hose. Extend hose to the farthest area of lawn to be treated
and work back toward faucet so that you do not walk over treated areas.
Apply evenly to lawn.
EXAMPLE: To treat 1,000 sq ft of fescue lawn, add 4 - oz of concentrate to the
sprayer with sprayer dial set on 1 - oz. Check the directions you received when
you purchased your sprayer for further details on the proper use of your dial
sprayer.
"CONCENTRATE-PLUS-WATER" SPRAYERS
For sprayers that require the addition of water as well as concentrate prior to
application:
1. From the following chart, determine amount of concentrate required to treat
2. Pour concentrate into sprayer jar to the required "- oz" level.
3. Then add the appropriate amount of water to the "gallons" level. Replace
sprayer top on jar and shake well before spraying.
treated and work back toward faucet so that you do not walk over treated
areas. Apply evenly to lawn.
EXAMPLE: To treat 1,000 sq ft of fescue, pour in concentrate to the 4 - oz mark
and add water to the 4 gal mark. Check the directions you received when you
Lawn Weed Killers
Apr 18, 2016 | Spectracide Bug and Weed Killer for Lawns...
Huskee Supreme lawn tractor runs for about 20 minutes then engines stops like it is running out of gas.
if it restarts after it sits a while you need to check the spindels on the deck one or both may have bearings sezing up after the run and heat up.
Apr 24, 2014 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Washer fluid not spraying out onto windows
when you push the button to spray the window "do you hear the sprayer pump motor"?
If no, your sprayer pump motor could have failed or come diconnected. now if you do hear the sprayer pump kick in then> check your lines "the small rubber hoses that lead to the actual sprayer nossels. make sure the small hoses are not damaged and leaking and not pinched or restricked.. in rare cases the sprayer pump could have failed and still make a sound like its working but not pump out any fluid.. also in some cases BUT RARE you could have a line or filter screen plugged inside the washer resivor.. Good Luck!
Sep 13, 2011 | 2003 Chrysler Voyager
Hi, I have a Craftsman LT1000 lawn tractor and yesterday while I was cutting down some really tall weeds it suddenly shut off on me. When I turn the key now, even with a jumper cable from my car to the...
first thing to do is pull your plug put the plug back in the wire hold it close to the metal block and turn the engine over and see if theres any spark
Jul 24, 2011 | Craftsman Garden
Pump is presurized but no spray
Most weed killers and fertilisers either crystalise or turn to gel when left unused. Pull sprayer wand to pieces and run hot water through the hose and wand, they especially clog up at the spray tip and at the on'off control.
May 14, 2010 | H.D. Hudson 1 Gal Poly Deck Sprayer
Windshield washer sprayer 4 front.....no no pump sound
The reservoir does not need replacement.
First check for burnt fuse.
Next check if the washer motor terminals are securely connected.
If you want to test the motor connect it to the battery and see if it works. If the motor is fine then this is a wiring fault.
The motor may also be clogged with things like small bits of paper etc.
Aug 17, 2009 | 2001 Subaru Outback
50'' Huskee lawn tractor only turns in one direction
the brand huskee is now manufactured by MTD
Parts are available from tractor supply company at www.tractorsupply.com
there are pages of not very encouraging reviews about the huskee mower or about the tractor supply company but you can contact them to see what you can get
as for the problem , if it is a zero turn unit it may be a clutch arrangement needs adjustment
If you do not get any help from that company, you could ring around the mower repairs shops to get an idea as what could be wrong as the principle of operation will be the same .
also there are sites that have pdf versions of the workshop manual for huskee
May 20, 2017 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Fimco Sprayer , 25 gallon, 2.1 gpm, 12 Volts - Blowing fuses
Soiunds like you either have one of two things. Either the pump motor is bad or you have a wire that is shorted out. look for chaffed or bare wires or burnt spots on the sprayer and the machine towing it. one of the two is your issue. Hope this helps!
Sep 19, 2008 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Garden Logo
336 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
