Question about Epson Stylus C88 InkJet Photo Printer
Solid ink red light on epson c88...already downloaded ssc utility but its not working
  • 369 Answers
Are you there?
Posted on May 05, 2010
  • sandeep kumar sharma
    sandeep kumar sharma May 05, 2010
    I am online. the session got disconnected.click on chat now, you will not be charged again for this.
Epson r230 red light blinking
Hi!
I believe your waste ink pad counter registers that it is already full.
You may reset this counter by using the SSC Service Utility for Epson.
You may download it here:http://www.ssclg.com/epsone.shtml
Reset and Reboot.
Feb 26, 2011 | Epson Stylus Photo R200 InkJet Printer
Hi sir my printer Epson R230 Not working that printer 2 red light blingking please help me
Hi!
your waste ink counter is already counting an overflow.
you may reset your epson printer by using the ssc service utility.
you may download it here: http://www.ssclg.com/epsone.shtml
Feb 22, 2011 | Epson STYLUS R230 InkJet Photo Printer
Red Ink Light is Staying on
You need to change your ink.
If changing the ink doesn't work for you, there is always a work around.
Go to this link and download the 'SSC Service Utility'.
After installing SSC, you can reset your ink status from your pc and you should be good to go!
Mar 11, 2010 | Epson C64 InkJet Printer
Green light out both red lights flashing alternately
If the lights are flashing alternately then this is the Service Maintenance request by the printer. Usually this is related to the ink pads. You will need to change the ink pads and use a SSC utility.
Feb 08, 2010 | Epson Stylus C88 InkJet Photo Printer
All lights are blinking, nothing is jammed. I also get "Parts are at the end of their service life" I already downloaded the ssc utlility and reset the counters, no change. Please help!
I reset the ink pad counter with the ssc utility, and that didn't work. Then I downloaded Epson's own reset utility directly from Epson, and reset the counter with that. Problem solved!
Oct 13, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Stopped printing both ink and paper red light
Depending on the way the lights are flashing you could be able to fix this reasonably easily.
If the lights are flashing at high speed together (ie: at the same time) then it's a fatal error and the chances are you have some kind of problem such as:
  • paper jamming up the works
  • loose wiring
  • the cleaning station sometimes pops up out of position and stops the printhead getting back into the parked position. If this is the cause you have to push the white wiper plastic down and to the right before allowing it back up and into the mated position with the parking pad. Takes a little work but it's easy enough.
Problem #2 is the waste pads and that's indicated by the flashing lights alternating rather than together.
If it's this then rather than reinvent the wheel (I've posted about this soooo many times now) here's a helpful little guide here:
http://www.octoink.co.uk/store/pages/Epson-C86.html (the C86 is the same as the C88 in terms of the waste pump/tubing design)
Resetting the waste ink counter requires the SSC utility from ssclg.com or a suitable adjustment utility which can be found for download if you search hard...
Hope that lot helps but if you get stuck, post again and I'll do what I can.
Cheers,
Martin
Aug 03, 2009 | Epson Stylus C88 InkJet Photo Printer
Green and red light flashing
SSC Service Utility allows you to do many things to your Epson printer, Work directly with CSIC in Epson Stylus printers cartridges, Freeze internal ink counters, Reset internal ink counters even with empty cartridges, Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode, Hot swapping of cartridges supported, Resetting of protection counter (even then it is already full), More then 60 different Epson printers supported This allows many people with high printing demands to save money (program works with both black and color cartridges).
May 12, 2009 | Epson Stylus C43SX InkJet Printer
2 red lites blinking no epson c88 printer
If both lights are flashing, it may mean the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can check this and restore your printer to a working condition immediately by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type, then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If none of this stops the two red lights flashing, you will need to have a technician check your printer - it may well mean the main board has failed.
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Mar 22, 2009 | Epson Stylus C88 InkJet Photo Printer
My ink is jammed fro epson stylus c88.
i would download the ssc and try reseting your printer
Mar 03, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson C87 Plus
I have the same problem. I put a bottle at the back of the printer and connect to the exhaust ink with elastic pipe. It's to replace the function of ink pads. So I don't worry that the waste ink will damage the printer circuit board. I use SSC Utility too.
Jan 17, 2009 | Epson Stylus photo C87 InkJet Printer
Epson Stylus C88 InkJet Photo Printer Logo
242 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
