Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AYM dryer works normal but continuously beeps intermittantly even with the dryer powered off. Cleaned exhaust vents and dryer internally. Beeping stopped for two or three days and started again. Rechecked exhaust vent, cleaned again but dryer still beeps.
4 Suggested Answers
SOURCE: maytag neptune dryer not heating up to dry clothes.
On my dryer the igniter is rt behind the front panel. Take off the dooe and a few screws and pull it off. If the igniter lights at all it is good. Try also checking the entire discharge vent hose as sometimes it gets clogged way dn line and you might not notice it. Try squeezing it all the way dn.
Posted on Mar 02, 2009
Illeagle
  • 525 Answers
SOURCE: My Maytag Neptune gas dryer gets hot for about 30 seconds.
Below is a link courtesy of www.repairclinic.com. This shows the Gas Valve Coils, which is the number 1 failing component.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG5500AW-%3d%3di3479&PartID=3479
Below is the disassembly/diagnostic procedures page that may help on teardown.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
For more information visit, http://homemanagement.services.officelive.com/FieldServiceHelp.aspx
Posted on Sep 23, 2009
SOURCE: maytag neptune MDE9700AYW ts t5 error
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Hope this helps
Posted on Feb 27, 2010
Brand new Maytag dryer has been coverted to propane and it keeps breaking (not heating up). The service contractor replaced some parts, tested it and worked fine for 1 day. Today I washed a blanket and...
even though the you might have a new dryer the vent line could be blocked with lint,or there are other parts that could go on a gas dryer,bad thermal fuse,gas coils,ignitor,sensor one of the thermostats,the only way to tell is to get in there with a meter,unplug the dryer remove at least one of the wires on the part you're checking and check the parts for continuity.that's a neptune those are the machines that put maytag out of bussiness a few years ago,i don't think it's new.you can go here and look up the parts i told you to check,if you need anymore help let me know.
Aug 24, 2013 | Maytag Neptune MDG5500AW Gas Dryer
It takes the dryer too long time to dry the laundry even on 80 degrees.
I took my dryer apart and found the vent shoot and exhaust needed cleaning. Also the exhaust vent pipe going out side should be cleande.
Dec 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Hi, my Maytag Neptune gas dryer will not heat up anymore. When the machine start to run, you can hear the gas is burning & the heat is blowing from hot to warm to cold in about 60 to 90 seconds that is...
The thermal fuse is NEVER at fault, it is only a symptom of some other problem and is a serious safety warning. Check that the exhaust vent is clean and not kinked or otherwise obstructed. When WAS the last time you cleaned the vent??
Sep 16, 2017 | Maytag MDE9700AYW Neptune 174 Electric...
Works for a few minute then shuts off and beeps quite often
check the exhaust vents for any lint build up which will shut down the burner electronicly
Aug 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I do not have a manual it and it will sometimes shut off and the letters PF are in the time box what is going on
The "PF" code means that a power failure occurred while the dryer was in operation. Unplug the dryer and check the main power cord. Make sure that it is connected tightly. One of the most common causes of this code is poor venting. Check the vent and ensure that it is clear and clean to where it vents outside. If these items are alright, then check the thermal fuse. It's about an inch long and is inside the rear of the dryer, usually attached to or near the exhaust duct. Test for continuity. A lack of continuity will mean a bad thermal fuse. I would really lean toward a venting problem first, though. Really sorry for your trouble and I hope this helped. Best wishes.
Oct 16, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a neptune drying center and it's taking 3 hours to dry
Check the exhaust duct again. There must be a blockage, a kink, or a disconnected vent pipe.
May 03, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
54 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
