Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
How do i incript my router so neighbors aren't getting free inter
Was having problems with speed of computer. one neighbor has 3 computers i belive there using my wireless.they asked if i had a password didn't think anything about it untill now. i have the motorola surfboard sbg900 router. hope you can help thanks
SOURCE: can't open my NAT
Hi there.. i had that problem too and i just solved it...
heres the thing..
first you go into the router setup page.. which is.. 192.168.100.1
go to the gateway tab
go to port forwarding tab
go to config
thenTemplate --> custom
Name--> whatever
Port start--> 88
Port end-->88
LAN IP address--> check on your xbox on network settings and copy the same ip address.
Enable --> checked
Then click add.
After that.. you will do the same thing but on the port option you will put 3074. add it ..
now your nat should be open. ;)
Posted on Jan 07, 2008
  • 135 Answers
SOURCE: Motorola SBG900-SiS191 Ethernet Controller
Setup your IP addresses correctly by checking available IP addies in router.
You will have to know your router addie and your available wireless addies (in router). For this you need to enter router configuration (read manual).
Open network properties, tcp/ip properties, check "use following ip addie and enter something like 192.168.1.5 depending on what your router is setup as available.
Enter same subnet as your router.
Enter DNS server addies from you ISP.
Posted on Feb 19, 2009
zazonker
  • 68 Answers
SOURCE: Unable to set up wireless router
Shut down your computer, unplug the cable modem and the switch. Connect all three - computer to switch, switch to modem. Make sure that the ethernet cable between the router and the modem is in the router uplink port and that the computer is plugged into one of the four ports that look alike. Wait 30 seconds - plug in the modem. Wait another 30 seconds, plug in the router, wait another 30 seconds and boot the computer. Open a browser and see if you have internet access. If you still don't, then try to check the browser by typing 192.168.1.1 into the address bar of the browser. That should give you the browser sign in screen. The Linksys default is to leave the user name blank and type admin for the password. That should give you access to the router so you can check the settings. If this doesn't work, document carefully what happens and post again with your results and we'll try to go from there.
Posted on Jun 08, 2009
  • 31 Answers
SOURCE: How can I change my motorola surfboard wep key
Reset the router to apply factroty default settings, It's simple , Press the restart button on the back side of the router , Make sure power is on while pressing the reset button , Press it for 30 secs at least and then turn off for next 30 secs, Turn it back on , Router will get all factory default settings.
For any help feel free to contact me +91-9958531192 or email me chandankumaar@gmail.com
Regards :
Chandan
Posted on Sep 10, 2009
  • 112 Answers
SOURCE: How do I setup password on my motorola wifi unit?
Here are the steps to setup security on your router.
  1. Login to the webinterface of your router. The default ip address is 192.168.0.1
  2. The default userid is admin
  3. The default password is motorola
  4. Go to Wireless / Security
  5. Select WPA-PSK and TKIP
  6. Enter an encryption password
  7. Apply and restart the router
  8. That's it for the router --- On your workstation, when you try to attach to your router, you'll see it is secure. Enter your password and you're all set!
Please let me know if this has helped or if I can be of further assistance. Thank you.
Posted on Sep 19, 2009
Can i connect to a wireless network like wifi without a cable network
Yes but you will still have some kind of computer sevicenetwork to receive the signal to the wiireless wifi..unless you have close neighbors who have the service and have their Wifi set for others to use...example stores and restaurants that have free WIFI where you are using their service..only in this case your neighbors..good luck..
Oct 05, 2014 | Computers & Internet
How can I remove my neighbor from my network
Easiest thing to do, Change the password to your router. Once this is done, it will prevent your neighbor from any further access to your router and of course prevent internet access. Most all routers are simply a local web address for access. Example: 192.168.1.1 typed inside a browser address pane will take you inside the router. Check your router for setup procedures.
Have a great night..
Sep 09, 2014 | Linksys By Cisco E2500 DualBand WirelessN...
I seem to be stuck at 20mb downloads when im supposed to get 30mb from time warner
Have you called TW yet? They will probably say that the 30Mb is a "burst" speed. Since you are using a cable modem - your connection is pooled with those of your neighbors. If you live in a particularly busy neighborhood, your speed will suffer.
This could technically also be due to a faulty router or cable modem. Do you get full speed when connecting your cable modem directly to your computer?.
Jan 14, 2014 | Computers & Internet
I have a Dell Vostro 1520 laptop with a Dell 1510 Wireless-N card. At the moment, I'm connected to my neighbor's wireless internet. I'm in a basement and the neighbor's house is about 10...
Try placing your laptop as close to the location of their router, removing barriers like walls for best speeds. Maybe your neighbour is having the same problem. Have them unplug the router for 10 sec (no more). Power-cycling once-a-month or so, is a good thing
Apr 04, 2017 | Dell Computers & Internet
How can you use public access on your desktop and netbook with a netgear router and adapter walmart sales lady said it can be done with just the router and adapter setup everything we needed was in the...
Just having the wireless router without connecting it to cable modem or DSL modem will not allow you to get onto the Internet. The wireless card in your computer/laptop will allow you to get onto the Internet at a free public WiFi hot spot location such as McDonalds, Star Bucks, at the airport.
Also the wireless card in your computer/laptop may allow you to connect into an unsecured wireless router from your neighbors, if their wireless router is within range of your computer/laptop but without their permission to use their Internet, it is considered stealing from your neighbor. They have a set download limit from their Internet Service Provider and by you connecting to their ISP you may cause them to exceed their download limit and they would be charged additional costs for every Mega byte over their limit.
Sep 28, 2010 | NetGear RangeMax Dual-Band Wireless-N...
Im only recieving 1020 speed download, when should be atlwast 8
First, if you are connecting to the router with wireless, there are a couple of possible problems. If you are using Wireless B, you'll probably only get around 4 or 5 mbps at best, and even with wireless G, if you happen to have your router set to the same channel as your neighbor or several of your neighbors, it will slow down a LOT and could even have trouble staying connected. To check this, try plugging directly into your router and disabling the wireless on your computer temporarily and run this test again. If it is much better, try changing your wireless channel.
Second, I'm not familiar with this particular model of router, but I've found that many of the cheaper and/or older routers cannot handle the current speeds we see on cable and DSL connections. This could also be a problem with your cable or DSL connection. To check this, you can temporarily bypass your router and plug your modem directly into your computer. Remember this exposes your computer directly to the internet, so it's probably not a good idea to leave it that way. You may also have to reboot your modem and even reconfigure it and your computer to do this depending on your ISP. If it is still slow, you will need to contact your ISP and complain!
Mar 09, 2010 | Belkin (F5D7231-4) Wireless Router
I bought a new computer and need my security key
That does not work because it is your neighbors .That is the common gateway, so all the neighbors that did not change it will have it too.
You need to reset tour gate way, you will get a new one that should work.
Jan 16, 2010 | Linksys -Cisco Wireless-G VPN Broadband...
My neighbor is using my wirelss service and I want
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Click Here for step by step instructions
Jan 15, 2010 | D-Link AirPlus DI-524 Wireless Router
This router will not keep a stable wireless connection; it works fine for ethernet; we have loaded upgrades to the router . This problem exists for four laptops we have tried it with. A;; of them work fine...
Do a wireless scan on your computer and out how many wireless access is in your neighborhood. More than likely that your router is sharing the same wireless channel number as your neighbor's. Go to your router and cheange to opposite of what your neighbor is on.
Dec 21, 2009 | Linksys Wireless-G WRT54GS Router...
I can log in to yahoo but i can't get my e-mail.
If you are using a router try lowering the the MTU on the router's configuration page the default is 1500, lower it down by 1492 if this doesn't resolve the problem try locking the WAN ports speed of your router to 10mbps or 100mbps.
Mar 01, 2009 | Yahoo Mail
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
43 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
