Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Colors are out of focus and magic focus wont fix
The alinghnent of the colors are off and i cant get the magic focus to reset to the proper position
  • 438 Answers
If you have tried the customer convergence menu/control and can not set the convergence you have a fault with the electronic circuit that controls the convergence of your 3 picture tubes this overlaps the 3 colors red, green, blue to create the proper color combination's of colors for a proper picture
Posted on May 05, 2010
    Scholar:
  • 70 Answers
Sounds like the convergence circuit on the set has developed a problem. The unit should be looked at by a qualified technician. Expect a repair cost of 150 to 200 dollars depending on the number of parts that need to be replaced and the shop labor rates in your area.
Set 51uwx20b, how do i fix magic flash to reset factory settings
Convergence board needs repair, google you model # and see if you can purchase a repair kit.
Nov 22, 2011 | Hitachi 51UWX20B 51" Rear Projection...
How do i adjust the magic focus?
  • Press "Menu" on the remote select the "Magic Focus" option in the Video menu or press the "Magic Focus" button on the front panel to adjust the convergence of the three picture tubes that create the proper color for the picture. Pressing the button on the TV initiates the automatic adjustment, and accessing the feature through the Video menu allows you to choose automatic or manual adjustment, though the "Automatic" setting must be selected for the button on the front of the TV to begin the process.
  • Aug 04, 2011 | Hitachi 53UWX10B 53" Rear Projection...
    Go to Encompass Parts Distribution and type in your Model number they have free service manual you can print out on line. they also list 393-399 Parts for this model.
    May 08, 2010 | Hitachi 57F500 57" Rear Projection...
    Picture is out of focus. Tried Magic focus - didn't work. Saw color grid; appears blue is out of whack.
    There are two common problems with these sets.
    Problem #1) Convergence
    Symptoms:
    • Screen Looks 3D
    • Colors wont align
    • Video may look distorted
    Problem #2 CRT Fluid has clouded over. Symtoms
    • Dull looking video
    • White looking video
    • Halos around objects
    • Red/Orange looking video
    You can see some examples and find a fix here...
    bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
    Oct 18, 2009 | Hitachi 57SWX20B 57" Rear Projection...
    My colors are splitting inthe picture. How do I fix?
    I think you have a convergence issue. Are the colors not properly aligned - do you see multiple overlays of the same image in different colors?
    If so all you need is to adjust the convergence - it should be adjustable in the user manual or by pushing the "Magic Focus" button if you have one.
    Jul 30, 2009 | Toshiba 50H71 50" Rear Projection...
    Have a 53" Hitachi HDTV that bows at the top and the bottom. I was told one of the transitors or transformes blew. I also do not have the regular magic focus just the static focus now. I tried to alli
    Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
    This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
    Common Symptoms include....
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
    Here are some photos of convergence problems.
    Here is a quick test....
    Using your original remote go-to the settings menu then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
    If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
    Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
    69189a5.pngCONVERGENCE SOLUTION
    You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
    This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
    May 03, 2009 | Hitachi 53FDX20B 53" Rear Projection...
    Yellow and blue color ruins total picture on 50" tv,can't get rid
    lupe0112,
    I'm no expert, but I think that you have a problem with the convergence of the 3 color guns. I've been working on a similar problem. As a first step, have you tried "Magic Focus?" The Magic Focus button for the Hitachi 53UDX10B is at the left of the small front panel controls that also include your RCA composite and SVideo connectors. Let the set warm up for about 20 minutes (as recommended by the user guide), and then press the Magic Focus button. When you press the Magic focus button, the set will auto align the 3 color guns. If this doesn't fix your problem, unplug the TV for at least 4 hours and try again.
    Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
    Model 53fdx20bv2f012705
    I have the exact same problem.......you just explained it a hell of a lot better than me. In the magic focus was red broken up, blurred and flashing as well as only 3 bars???
    If you solved your problem could you please get back to me.
    Thank you
    Randy
    gardner7768@msn.com
    Apr 16, 2008 | Hitachi 53FDX20B 53" Rear Projection...
    Hitachi 51f500 magic focus
    convergance amp ic bad
    · http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
    · http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
    Dec 12, 2007 | Hitachi 51F500 51" Rear Projection...
    Hitachi 61SDX picture got dim shows Code 3
    use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
    Nov 17, 2007 | Hitachi 61SDX01B 61" Rear Projection...
    Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
    155 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
