My Kenmore washing machine doesn't shift to hi-speed during the spin/drain cycle. The clothes are still soaking wet after the washing cycle.
  • Washing Mach... Master
  • 43,501 Answers
Here is a tip that I wrtoe about washing machines that don't spin out right..
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on May 05, 2010
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Why did my washing machine stop spinning?
Not knowing the age or model of your washer it's hard to say but if it is the older direct drive then it's a bad lid switch!
Dec 08, 2015 | Kenmore Washing Machines
Have a kenmore washer and I have to run everything thru 2 spins cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn clutch.
Oct 25, 2011 | Kenmore 22422 Top Load Washer
When the washer enters the spin cycle, it doesn't speed up, leaving the clothes still soaking wet when done
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 21, 2010 | Westinghouse Washing Machines
Clothes are very wet after spin cycle This unit has several spin speed settings, machine does spin but not fast enough to remove water from clothes
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Sep 16, 2010 | Kenmore Washing Machines
Kenmore 22622 will not shift into high speed during spin cycle leaving clothes very wet every now and then it will go to high speed. i tried turning the dial around a couple of times and it went into high...
Possible overloading or a situation many people do not consider is underloading ,if your machine has an out of balance sensor this will operate in either event and hold the spin to protect your machine .
Nov 03, 2009 | Kenmore 22622 Top Load Washer
I have a Kenmore frontloading washer, model no. 417.42042100. At the end of the wash cycle, the clothes are still very wet; that is, still SOAKED with water, even though all the water has been drained...
HI. your unit is equipped with a spin control board. this board, if damaged, will not initiate an adequate spin. This will not allow for proper drainage and drying of the clothes. The spin motor regulates the rotation speed during the spin cycle. It seems to be the culprit at this time. Have the spin board replaced asap.
This part will usually cost around $150.00 at the most.
Aug 27, 2009 | Kenmore Washing Machines
Clothes coming out of washer still soaking wet
is it a kenmore top load?if so the motor is not kicking in to 2nd gear for high fast spin,does it have a speed control on the head?are you using it on the reg. wash cycle?-mike
Apr 18, 2009 | Washing Machines
Clothes wet, doesnt spin fast
Check the drain spigot, where the drain hose attaches to the drain trap under the sink/tub.There may be a blockage in the spigot which is causing the water to drain very slowly and therefor not allowing the machine to spin at normal fast speed.
Oct 22, 2007 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
248 people viewed this question
Top Washing Machines Experts
