Question about Proform 380 Treadmill Walking Belt
I have a proform380i that makes a lot of noise when started... I think it needs oiling .... where do i put the oil in the treadmill ?
    President:
  • Proform Master
  • 832 Answers
Unplug unit remove motor shroud then plug unit in then start it observe where the noise is coming from. The best way to check the rollers to see if the bearings have failed is using a long shafted flat tip screw driver and place it on the shaft of the front roller, then put your ear on the handle and listen, if the sound has amplified then the roller is defective and needs replacing. If not then check the The drive motor the same way last but not least check the rear roller by placing the screw driver on the end of each adjusting bolts. If the noise is a squealing noise then it could be the drive belt .Call Icon Fitness to order part their is 1-800-999-3756.
Posted on May 05, 2010
I have a ct83 horizon treadmill, recently there is a bubble in the walking belt that makes noise
Because of the continues usage, It will get spark and make noise. This can be prevent by painting or just put some oil to the engine.
Sep 01, 2016 | Horizon Ct 83 Treadmill Walking Belt
For the last couple of days tread belt seemed to be pulling a bit hard and smells a bit of burning when stopped,tonight i switched on bit of a clunk and belt would not turn kicked foot on belt it started...
treadmill belt need always to put a special oil from below, for better sliding. it is a special product you can find it at any service center for treadmill.
Nov 15, 2013 | Exercise & Fitness
Oil light on and engine making a lot of noise
put oil bank in the crankcase. the dip stick shows this.
always check oil levers. every 2nd fill up.
all engine burn oil. All.
Mar 19, 2013 | 2006 Suzuki Forenza
I have a 1998 chevy cavalier with a 2.4L under the hood. No it is not the z24 it is a 4 door that came with the big 4 cylinder. Now I just got my oil changed and a day later the car started to make a funky...
take the car back to the place you had the oil changed and tell your story sounds like the oil plug or filter was left loose . i think your 4 cylinder is oil pressure senative . i mean if you loose oil pressure the engine will stop
Feb 23, 2013 | Cars & Trucks
Memory Craft 7000 making terriable noise
the machine is showing it doesn't need oiling or the manual says
it's a self oiling machine?
if the machine is self oiling the DON"T oil the machine.
if you think the noise is from the tension dial,, the try using a can of
air or unwaxed dental floss on the tension dial if you have access
to the tension dial.
or the machine may need to be checked to find why it's making the
noise. the machine may just need some adjustments or a tune-up
depending on when the machine has been serviced last.
Dec 12, 2012 | Janome Memory Craft 5700
2003 impala LS making loud ticking noise on cold starts, subsides when warm
yes chevys 3.4 and 3.5 have common lifter noise, have you checked the oil level. I would a better oil ,and I put lucas oil treat in my customers cars after oil changes
Nov 11, 2012 | 2003 Chevrolet Impala
I have a 680 proform trainer and the motor is very very loud. what do I need to do to fix it?
Try to put some oil in bearing of motor. For oiling the motor bearing you have to open the top cover. Be sure to remove the power before opening the treadmill. Normally bearing makes noise may be because of insufficient lubrication Or the bearing itself is faulty. Check is the lubricating reduces the noise or not. if not then you have to call for a repair man to change the bearing or replace the motor. un the following link you can fin the motor for your treadmill. Be sure that the power is remove before opening. because all treadmill's motor control circuits are live if there is power.
Motor
Ajin
Jul 21, 2012 | Proform Power Series 680 Treadmill Fitness...
Oil presure low on start up, rod noise for first 15 sec if temp below 30
You need to switch to synthetic oil as soon as possible! When you change the oil, make sure that you are replacing the filter with the correct one. Some filters contain an anti-drain back valve that prevents this problem. The synthetic oil will flow more rapidly when cold and prevent the epidemic problems that toyota has had with sludge build-up.
Please google: "toyota sludge"
Mar 26, 2009 | 2000 Toyota Tundra
Lifter noise when on start up then goes away after few minutes
These engines did make a little rattle when first cranked. Are you running an ac/delco filter? i have seen a lot of engines make noise from cheap oil filters. they will let all the oil drain out so when you start it has to fill the filter back up before getting oil to engine
Nov 11, 2008 | 2004 Chevrolet Impala
Proform 380 Treadmill Walking Belt Logo
268 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
