Question about Jabra BT125 Headset
The over the ear arm is spliting and will break in half soon. Where can I get a replacement arm?
    President:
  • 1,118 Answers
You will find it at Jabra's online store (direct link here). You could also find them on eBay, but after a brief pick I've just done there, all of them, at least at this time, are, believe me or not, more expensive.
Cheers! Carlos
Posted on May 05, 2010
Gauge will move to half then to empty when it almost full of fuel
{: ) That's a typical symptom of a failing or faulty fuel level sensor that needs to be replaced. In your case, you are aware that your fuel tank is almost full, and you expect your gauge to read accordingly. What happened there is that when the level arm reached the half point, there was a break or jump. That point is the high resistance area. When the engine module detects this break or error for only a few seconds, it will automatically reset your gauge to zero reading.
Aug 05, 2011 | Dodge Neon Cars & Trucks
Fuel injectors , how do you change them ?
if its like mine, you'll have to change the whole spider injector assembly, it is located under the throttle body, remove the 10 bolts holding the top part of the splite intake, unplug everything, it looks harder than it is, once you have the plastic part of the intake off, its right infront of you, follow the hoses to each cylinder, and u will see 2 ears sticking up, pinch them together and pull up.
Feb 05, 2011 | 2000 Chevrolet S-10
Wiper arm has come loose due to ice how do I tighten it please!
It useually clip in with a plastic clip, if that is broken use a cable tie for emergancy only and replace as soon as possable,if the clip did not break, boil water put in a cup, warm up the clip (still attached to the arm) and clip it back on and let it cool down naturally
Dec 11, 2010 | 1997 Land Rover Discovery
How do i remove cv anxle on front of my 1991 geo prism?
  1. Remove the tire, caliper and the rotor
  2. loosen the cv axle nut on the axle
  3. remove the nut from the lower balljoint
  4. use a balljoint spliting fork to break control arm free from spindle
  5. pry down on control arm and move spindle to side and pull axle out of the spindle, use some wire to tie spindle off to the side.
  6. use a pry bar and pop axle free from the trany, slide axle out of the trany, reverse to install.
Oct 24, 2010 | 1991 Geo Prizm
Mounting ears are molded in plastic. Use these;
Do you have a model number or picture?
I am trying to figure out which component you purchased.
Most flush valves have posts / ears at the base. Mostly they used to secure the flapper to the flush valve. There is no need to break them off.
Let me know which component you are replacing. I can better assist you if you's supply more info.
Dec 21, 2009 | Ldr Industries Home
Brake in front left is knocking / clacking
More than likely it is your control arm, or a strut. It only does it when you apply the breaks, i think it is the control arm. Need to get fixed as soon as possible.
Nov 18, 2009 | 2002 Mitsubishi Galant
94 chevy cav. after driving for a while, the car shuts off when u break. it will start back up but stalls as soon as you put it in a gear. let it sit for half hour and it will drive again for a while then...
94 chevy cav. after driving for a while, the car shuts off when u break. it will start back up but stalls as soon as you put it in a gear. let it sit for half hour and it will drive again for a while then starts the process all over again. any suggestions
Oct 26, 2009 | 1994 Chevrolet Cavalier
Stop ligth switch
it on break petal arm half way up mark old one for ref
Dec 06, 2008 | 1996 Chevrolet K1500
SPEAKERPHONE ONLY ON SOME CALLS!!!
you need to replace the ear-piece flexcable and have them replace it.
Jun 26, 2008 | Motorola Mobility RAZR V3
Jabra BT125 Headset Logo
146 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
