How i tested if the back ligh is working I did change 3 times and no one is working I change the lamp and still no working
  • 11,896 Answers
Check the ballast and look for any capacitors that could be swollen. A bad I/C will also cause this.
Posted on May 05, 2010
Drving lights (running lights - in driver side rear) are out on my GX470.. HOw do i fix them??
you mean the park lamps.
the park lamp (HL switch 1 click, is park or as some call it tail or other running. same o samo)
the park circuit is the most complex lighing inthe car.
2 front, 3 rear.
4 sides.
and 10 in dash. and console, as many as 20 in all.
so if all work but some, the lamps are out, replace them.
how , as in how to remove them. ok.
there are basically 3 ways from 1920 to now, all cars on earth.
1: take out the lenses screws and , remove bulb
2: if no screw, look behind lamp. see screws, or nuts, bingo
3: last, on some cars the lenses pry out. do this last so you dont break the lenes.
there are exceptions, on some cars ring snaps on the lens locking it. pry it off,
in most cars, open the operator guide, see index
see lighting, turn to that page see lamp change out, bingo
lost the op guide?, Google will Find them all,, no need to guess, RTM.
Oct 16, 2013 | 2004 Lexus GX 470
Vizio LED LCD picture flickers
Turn the backlight down all the way in the menu. Fixed mine after a year of banging on the back.
Jun 20, 2012 | Vizio E320vp 32 Lcd Black Led Hdtv, -...
When i on my sony wega tv green light flash then turn on red ligh and flash 3 times
Most Sony (not all) 3 blinks is lamp door not properly closed.
It means that but not really: On some models it means the door has become warped from heat--I can tell you a easy way to prove if this is your problem.
Front shield has to be on these removed (outer one the covers lamp door)
Let me know and I would be happy to explain further.
Mar 19, 2012 | Televison & Video
My KF e50e10 lcd suddenly just shut off an when i turn on the power standby ligh flasher gren for a bit then shuts off red
When did you replaced lamp last time in tv?
If lamp has not been replaced in last 2-3 years then it is lamp that is dead and need to be replaced.
Lamp replacement procedure is easy and written in user manual of tv.
Thanks.
Apr 14, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Ep 2030 error code c06
Exposue lamp, does the lamp come on under the glass at all. Open close the front door, if that code comes back your exposure lamp is gone. Thats the bright ligh that comes on while making copies.
Jul 16, 2009 | Minolta EP1030/1030F CS/PRO Copier
Replaced lamp on sony 60'' sxrd tv and now get 3 red blinking ligh
I am having the same issue, just replaced bulb not it blinks 3 times. Any ideas?
Mar 26, 2009 | Sony Televison & Video
Hi there
turn set on with lamp in and lamp cover also,and after tryin to tur on ,red ligh its going to start flashing a segment of times.
Let me know how many times is blinling?
Jul 01, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Scanner
Hello, i have changed 2 registry keys. Now my scanner works without warm up, but i don't know, if they are resettet automatically after a period. I have tested this only a few hours and it worked. Please test it.
HKEY_CURRENT_USER\Software\Canon\ScanGear\8.6\Devices\CNQ4200
Key Energy save changed to 1
Key Lamp Off Time changed to 0
Greets
Holger
Nov 16, 2007 | Canon CanoScan 4200F Flatbed Scanner
Computers & Internet Logo
David Payne
David Payne
