Question about Honeywell Programmable Thermostat Heater
Screen freeze honey well heating and cooling touchscreen freeze how to release to normal
    Novelist:
  • 135 Answers
Try pushing hard and steady on the bottom, left side of the thermostat, if it unfreezes, it means that the ribbon connection from the base to the touch screen is loose. you can try to wiggle it, but usually it will not stay fixed and the thermostat must be changed.
I'm very sorry.
Sincerely,
Paul Gibson
Posted on May 07, 2010
While in heat mode the condenser freezes up.1200 model
This is how air conditioners work.
They transfer heat from (usually) hot places to cooler places.
When working in the opposite direction, the machine is attempting to pump heat from the cool place (making it colder) to the warm place (making it warmer).
Flushing the frozen condenser with cold water adds more heat to defrost the condenser, but it will refreeze when you try extracting more heat from the cold place.
Dec 10, 2013 | LG LS-K1830CL Cool Mini Split Air...
Belive thermat is sticking because temperture goes up and down
to hi temp kills all,even you and I.Is electric fan coming on at time of hi temp?Is it blowing/running hard/fast.no to either question is a fan issue.oil on stick of normal golden honey color?not milkey?If so,head problem.can pressurize cooling system also.Remember this if anything--you have an alum. head and can NOT take excessive heat.address problem immediately to prevent major $ issue.
Feb 24, 2011 | 2005 Chrysler PT Cruiser
Thermostat i had before was old so the home owner need a honey well type thermostat
Heating only. Cooling only. Combination Heating and Cooling
Oct 13, 2010 | Heating & Cooling
I am losing heat even though the heat gauge is almost at 210. What needs to be replaced?
You probably have a plugged heater core or radiator.Very common for these models with the dex-cool anti freeze.Check the hoses going to the heater core.They should be hot to the touch.Not warm but hot when the vehicle is at normal operating temperature.When it is cooled down and there is no pressure on the radiator cap,check the radiator and make sure the system is full.If the system is low you will not get heat.If this is the problem then check for leaks.If this has a 4.3 look for and intake gasket leaking.Hope this helps.Good luck.Let me know what you found.
Sep 15, 2010 | 2001 GMC Sonoma Extended Cab
The lap top is hot to touch but it dousnt freez
This is normal to all of the laptop, you can purchased some cooling products to reduce some heat coming from your laptop
Aug 08, 2010 | Toshiba Computers & Internet
Whirlpool 25.6 cu. ft. side by side Refrigerator with in door ice
The process of Refrigeration is for one section to be hot while cooling another section. I.e freezing in one section result in the heat build up and dissipattion else where. Any compressor working properly is going to be quite warm to the point of being hot to the touch when working NORMALLY. There is nothing that you need to do for the continued safe operation of your compressor. If your freezer has ice build up again in the near future your uint is not defrosting properly. If it functions normally after 2 or 3 days of use then you more than likely had a one time buildup of ice usually caused by someone leaving the door partially open
Jan 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
No heat
My 2005 Nissan Sentra 1.8s with 55,000 mi. blows cold air from the heater. Coolant not circulating in engine. Lower hose stays cool to touch. Both heater hoses cold. Changed thermostat - didn't fix it. Coolant not leaking or dirty. None in oil - no oil in radiator. Changed worn water pump belt - pump spins freely with no noise or resistance. Cooling fans come on after warm-up. Temperature gauge stays in normal range then jumps to hot and back again. Coolant good to 10 below - didn't freeze here yet. No other problems or repairs to car. Afraid to drive and make worse. Help!
Oct 10, 2009 | 2005 Nissan Sentra
My itouch has freezed
Try this: Press and hold the wake/sleep button and the home button simultaneously for ten seconds and the apple logo should appear on the screen. Release the buttons and it should work like normal. Hope this helps. If it still does not respond to touch, then your screen may have been damaged in some way and it will need to be replaced.
Jun 09, 2009 | Apple iPod touch
Froze apple touch ipod
Mar 17, 2009 | Apple iPod touch
Gateway laptop 450ROG freezes up after it gets hot & screen frzs
This definitely sounds like a heat problem. The system fan should cool it, but there may be a lot of dirt in the heat sink or along the path that the fan blows air. The first thing I would try is to get a can of canned air and blow it into all the vents under and on the side of the computer. If it is dusty, keep your face away.
You didn't say, but if you let the system cool down for a while (maybe 15 minutes or so) and start it up again and the same thing happens, it['s definitely a heat issue.
Feb 08, 2009 | Gateway 450ROG Notebook
Heating & Cooling Logo
237 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
