Question about Refrigerators
On aKenmore System 2000-model# C6467066882-- fridge is running normal but red service light comes on.Only thing not working is the alarm for when door is open for a minute or more.Is that enough to trigger the service light on that model? Thanks Rene
  • Rene Matz May 05, 2010
    Yes I,m sure also thats what the problem is-I may
    have to disconnect alarm --guy,s wife is worried
    because red light keeps coming on.
    Thanks. Rene
  • 11,896 Answers
That would likely be the problem. You can test the alarm if you feel necessary. Most people like to disconnect these anyhow.
Posted on May 05, 2010
  • Nate Stansfield
    Nate Stansfield May 05, 2010
    Not a problem. Thank You!
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
My sub zero service light and EC 24 are flashing, fridge is getting warmer...suggestions?
The ec 24 alarm is from a sensor that is located behind the freezer wall and connects to the control board in the ref. When the temp gets to a certain point the sensor will trip giving the alarm. If the temperature in the freezer is gone up but is around the 20 -30 degree F range, I would remove the grate that covers the compressor and check to see if the fan is running and if the coils are dirty. Either one of those can cause temps to go up. If the fan is running and the coils are clean, Call a service company because you possibly have a sealed system issue
May 06, 2012 | Sub-Zero 632 / S
Our headlights and tail lights are stuck on and van will not start, we were changing the stereo and the alarm beeped like it was unlocking. what could be wrong with it
Are your headlights and tail lights hooked into your alarm system (the flash when arming and disarming). You may have used a wire that was part of the alarm system. Does your alarm system kill the ignition so the van cannot be started? Could have done something to destroy the alarm system.
Might want to start by going backwards. Take the stereo out and putting any wiring back to the way it was before until things go back to normal. If that does not work then take the alarm out and repair any wires that have been cut and spliced for it.
Sep 03, 2011 | 2000 Ford Windstar
My jimmy starts and runs when it wants to then sercruity light comes on and shuts it off
Yes the truck came with a stock antitheft system. That IS what the security light is about. Check out this link. Everything you need to know is there.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Apr 24, 2011 | 2000 GMC Jimmy
Alarm Light constantly lit
You are in valet mode. It means the vehicle will lock/unlock but not arm the security system.
Open the door then hit lock then unlock and lock. Led will now turn off and work as normal.
Apr 04, 2010 | 821001/2100 2100 Security System
2000 Cougar no lights/brake lights and Alarm w/mind of its own
If any wires were crushed and momentarily shorted, it can damage any lighting/ alarm or other control module in the system. Only thing you can do is physically go over the harness and check for damage, pinched leads or missing grounds. If everything appears good, find the module and replace it (scrapyard part is cheaper than new) Accident damage is different than "normal" failures and can't really be diagnosed online because things can happen in an accident that never happen in normal use. All situations are different (angle of impact, location of impact, component shift and "bounce-back" as well as quality and care taken during repair work) Even if it was my vehicle, I'd need to go over the entire thing in order to locate the problem.
Good luck
Aug 31, 2009 | 2000 Mercury Cougar
Toyota 2000 Landcruiser Pardo remote need to reprogram
forgive my poor english/do U have a challanger alarm in Your car?If U have U must programm Your pilot in service because challenger has a radio device to programing pilot to the system
May 17, 2009 | 2000 Toyota Land Cruiser
2000 Toyota Corolla wont start Changed 02 sensor disconnected bat
that red LED is the Alarm, if its solid red, its fine; blinking is about to trigger I think and off means the Alarm is active and opening a door will set it off.
as to why it wont start...not a clue,
check gas, make sure its in park,
you said its turning over but not firing, perhaps its a bad sparkplug or just flooded...
Apr 17, 2009 | 2000 BMW 3 Series
Car Alarm no longer works
You have Blown a Relay in the Alarm System. This VERY hard to Diagnose over the Internet. I would take it to the Person who installed the New alarm and have them run a Coder on it to locate the Relay at Fault.
Jan 14, 2009 | 2002 Mazda Tribute
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
