Question about LG 42PC3D 42 in. Plasma Television
I have a 42pc3d LG plasma and the remote controls will not operate the TV. I have the original remote and a universal remote which use to control the TV and the dvr but now neither remote works on the TV. The universal one still works on the dvr. I did change out the batteries in both remotes and cleaned the sensor on the tv with no luck. Any other suggestions?
  • 138 Answers
if your TV warranty is not out of date then claim a new one..however it takes many days to process
so I recommend you to troubleshoot your universal remote controller
i assume that you are using RCA universal controller
1. Press and hold CODE SEARCH until the INDICATOR LIGHT lights, then release CODE
SEARCH.
2. Press and release the device button for the device’s code you are retrieving (TV,VCR or
DBS•CABLE). The INDICATOR LIGHT will blink once then remain lit.
Note: For AUX, press DVD•AUX then the device button for the code you are retrieving.
3. Press and release CODE SEARCH. The INDICATOR LIGHT will turn off.
4. Starting with 0 on the keypad, press the number buttons in order (0-9) until the
INDICATOR LIGHT blinks.
5. The number which causes the INDICATOR LIGHT to blink is the first digit of your code.
6. Repeat step 4 until you have retrieved all three numbers in code..
RCA: 004, 005, 006, 012, 019 ,056, 057, 058, 155, 156, 171, 172
if it fails buy and try ge universal remote
NOTE
it is a good to note down down your code
Posted on Jun 14, 2010
Code for vivo tv using universal Panasonic controls
0483.0829,0918,0999. Check these setup codes. Try this link. http://electrohelponline.blogspot.com/ Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there.
May 18, 2013 | LG 42PC3D 42 in. Plasma Television
Remote On/Off not working - Sensor Broken
Hey, maybe you should try reprogramming your universal and see if that works. Might want to try testing all the codes that work for LG and see if they'd work. If that doesn't work, find a site like <a href="http://www.remotecontrolhookup.com/lg/">www.remotecontrolhookup.com/lg/</a> and see if you can find your original and buy it and try it out. If that still doesn't work, send it back and you may need to find a local tv repair shop to look at your tv rf sensor.
Jun 05, 2012 | LG 42PC3D 42 in. Plasma Television
Lg 42pg20 remote won't work how to program
Hello
Buy a univesal remote control, which have setup codes for LG tV. You can get this information from the catelogue accompanied with the remote control. There will be proceedings also to setup the remot to tV. Or get its orginal remote control from the authorised service center for LG at your town.
Feb 27, 2012 | LG 42PG20 42 in. Plasma HDTV
I NEED ALL IF ANYCODES FOR I DIGITAL RM-810 UNIVERSAL REMOTE N3965 TO USE ON MY VIVO HD PLASMA TV 50INCH MODEL NUMBER PDP50FHD PLEASE
Maybe see if you can find the original for your tv online, something like remotecontrolhookup.com or similar, may be what you are looking for?
Dec 28, 2011 | LG 42PC3D 42 in. Plasma Television
Bought a 42pc3d-ud Lg Plasma tv from someone without a remote so i bought a new remote. i do i program it
This is a universal remote u bought wright?Check ur tv remote owner manual follow the instructions and program in ur tv universal remote codes for ur tv universal codes.If none of the tv universal codes of ur tv model will work,return it.Try website like Remotes.com to buy the tv original remote or very close compatible to the original one.
Jun 04, 2011 | LG 42PC3D 42 in. Plasma Television
I have a 46" LG
The TV requires restoration due to jammed setting either because the remote control was damaged or power function buttons have been pressed too frequenly.
The following processes are recommended
1. Consider replacing the remote control possibly acquiring another on the market; for example, a universal remote could be acquired to replace the original provided with system upon purchase.
2. With the new remote acquired, perform a system restoration or reconfiguration; discribable
a. The universal remote acquired on retail would have a menu button where functions could be manipulated
b. The menu button once pressed should display options on which to select system reconfiguration
c. A system reconfiguration would reset the entire TV settings to a manufacturers default expected to fix any user alterations that might have resulted into a malfunction.
Once the entireprocess is complete, th TV should not operate undesiringly.
Caution Notes
1. Do not sit on remote control or press several button at the same time; could cause device to alter configuration.
2.Do not situate TV at areas that could directly place pressure on power button areas switches
3.Do not attempt to reconfgure the TV original setting without first refering to the user guide or contacting professional technical experts.
4. Finally contact technical experts whenever necessisary.
Dec 02, 2010 | LG 42PX5D 42 in. Plasma HDTV
TV NOT WORKING WITH REMOTE
Try a universal remote with the appropriate codes.  If that doesn't solve the issues, it might be your remote sensor on the tv is bad.
Mar 02, 2009 | LG 42PX5D 42 in. Plasma HDTV
REMOTE CONTROL DOES NOT WORK
ad remote usally droped or conecter wonttouch will have to order u a new remote thx for using fix ya lg.com has them or remotecentral ok
Feb 03, 2008 | LG 42PC3D 42 in. Plasma Television
Need Insignia TV code for my Sony Receiver Universal Remote Control
Try This link it worked for me.
www.insignia-products.com/universalcontrolcodes.aspx
Jan 06, 2008 | Televison & Video
LG 42PC3D 42 in. Plasma Television Logo
390 people viewed this question
Computer Repairing
Computer Repairing
