Question about KitchenAid KHTU100KSS Kitchen Hood
I have a hood system that need to be installed in my restaurant, what i need to know if there s any measurement rule for the hood has to be from the ground?
  • 8,197 Answers
Yes there is. But it is not from the ground but from the burners. From the burners it needs to be 36 inches above.
Posted on May 05, 2010
Testimonial: "very helpfull"
Why are vent hood needed in restaurants
Powered vent hoods exhaust smoke and heat while passive hoods allow makeup air in. What goes out, must be replaced as far as air goes.
Jul 24, 2017 | Kitchen Ranges
Tip
HOW OFTEN SHOULD A KITCHEN EXHAUST BE CLEANED?
The most common cleaning frequency is every 3 months. This can vary, however. The kitchen exhaust systems that need cleaning most often are those over wood-burning or charcoal-burning stoves. These should be cleaned every month at least, and in some cases as often as every 2 weeks.
Below are various types of cooking establishments and their most commonly recommended cleaning frequencies.
  • Wood-burning or charcoal-burning stoves, char broilers, 24-hour restaurants, some hamburger places: 30 DAYS.
    Many hamburger restaurants and fast-food locations: 60 DAYS.
  • Average restaurant, employee cafeteria, hotel or hospital kitchen: 90 DAYS.
  • Pizza places, convalescent hospital, small snack bar, oven hood: 180 DAYS.
  • Hoods over non-grease-creating appliances, such as steam kettles, dishwashers, soup vats, etc.: ONE YEAR.
Kitchen exhaust cleaning is a standard part of the routine maintenance of any cooking establishment. All kitchen managers or restaurant owners should be aware of its role in fire prevention and ensure it is done on a regular basis.
Restaurant kitchen Exhaust cleaning Hood Cleaning Services in California...
on Jan 19, 2017 | Miscellaneous
New battery went dead. pulled the fuses and checked for a short. Found the fuse that shows a short just don't know what it goes too
A voltmeter is NOT the correct tool to check for an "ignition-off draw". A voltmeter will show 12 volts if ANYTHING is operating.
There are some things that are SUPPOSED to keep operating when the vehicle is shut off. These include, but are not limited to:
> Powertrain Control Module keep-alive memory
> Radio preset memory
> Clock
> Security/ alarm system
> Remote control recievers (door locks, etc.)
What you need to know is how many AMPS are being drawn from the battery when the vehicle is shut off. This is done by using a shunt bar connected between the battery terminal and the battery cable connector.
Set the ammeter to the lowest setting (usually 2 or 5 amp scale) Connect the ammeter leads accross the shunt bar. Turn off all electrical accessories, ignition switch, etc. and wait for a minimum of 45 minutes for all of the computer systems to go into "sleep" mode. Then open the shunt bar and read the amperage.
The "rule of thumb" is 300 milliamps (or 0.3 amps). This is where you have a problem. Anything less than this is not a problem and is not the cause of your dead battery. My experience is that most vehicles built in the last 15 years or so, will usually measure around 150 milliamps if there is no aftermarket equipment installed. Please note that even this 150 milliamps will measure as 12 volts if measured with a volt meter. A 2 amp draw will also measure as 12 volts....However, a 2 amp draw will kill your battery overnight and the 150 milliamp draw won't.
May 22, 2012 | 1999 Jeep Cherokee
I have replaced a posiflex receipt printer with a Problem with the POS X BIXOLON Samsung Kps SRP350 Thermal Receipt Serial Drk Gray Ac Printer I have replaced a posiflex receipt printer with a bixolon...
If the print test works, then that rules out cables, etc. Definitely sounds like a comm setting issue. The most common problem with swapping serial printers is incorrect baud rate. Is that winpos from quest in Aus? I think they might use 9600 baud. You change the printer baud rate using the dipswitches under the panel on the bottom of the printer.
Jan 03, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
Restaurant Pro Express: I am trying to set-up my credit card section with ...
You have your business setup as a quick serve. For some reason, First Data requires that your setup be retail or restaurant. You will need to reconfigure your setup. Or if you still have tech support time, PCAmerica has a patch that helps this issue. For some reason, First Data knows nothing about this. If you haven't locked into a contract with them, I suggest going with Mercury. Usually better rates, easier to setup, and their tech support will work with you to get issue resolved. If you need help getting reconfigured, send me an email. sysadmin@ccybernet.com
May 06, 2010 | Pc America Restaurant Pro Express
Hood pins on a 1991 Pontiac Firebird
Find the point on the radiator support where the pins will be located.Be sure there isn't anything underneath to drill through.Measure from the fender to the center point of the hole location,and measure from the front fascia(edge where the front edge of the hood meets the body)to the center point of the hole location.Use these measurements to mark the hole on the hood.Repeat for the other side.MEASURE TWICE DRILL ONCE.
Sep 10, 2009 | 1991 Pontiac Firebird
I can<t restaure my Windows I lost my back-up
First of all, it is never a good idea to post your full name, address or phone number online.
Secondly you will need a system disc to re-install XP pro. You can restore your system to an earlier time by using the system restore feature in xp.
Hank
Jul 31, 2009 | Computers & Internet
Re-install old database in restaurant pro express
have you backup the system regullary? it does not do automatically. you nust have one back up file in order to restore you system
Mar 31, 2008 | Pc America Restaurant Pro Express
KitchenAid KHTU100KSS Kitchen Hood Logo
99 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
