Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
I have a delonghi Magnifica 3500, getting a message 'insert brewer filter'. followed manual instructions of cleaning and re-inserting unit, which clicks into place correctly. Upon restart of machine, message returns along with a very loud buzzing and vibrating noise when it does manage to cycle to the next step. Cust service with delonghi recommended to descale, and the same message stops my descaling process when i press OK to move forward into descale process. AHHH!
    Brigadier General:
  • 3,513 Answers
Please check the bellow link regarding your query…
http://www.ehow.com/how_6759265_troubleshoot-delonghi-coffee-maker.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 09, 2010
DeLonghi Rialto EAM-4500. When I turn it on, it makes loud noises and give me the following message:Ground too fine adjust grinder and insert water spout
Step: 1 Switch off your coffee maker. Remove the first brewer unit. Wash it thoroughly under running water.
Step 2: clean the coffee grinder using vaccum cleaner.
Step 3: switch on the Machine !!! Make Coffee
(Note: if you hear loud noises during coffee preparation then please use food graded grease to fix it)
Mar 19, 2017 | DeLonghi Coffee Makers & Espresso Machines
Delonghi magnifica raid cappuccino keeps on displaying insert grounds container when all clean and inserted please help can not get it to work
looks like the micro switch on the bottom might have some coffee grounds and prevent the grounds container from correctly closing
Clean with old brush and re insert.
If you still have a problem....it could be the micro switch
Nov 15, 2016 | DeLonghi Coffee Makers & Espresso Machines
Your question: "I have a Delonghi magnifica 3300 that is 7 yrs old. It doesn't heat the coffee very good and the steam frother doesn't work well either. I have always used filtered water and descale i
If heater not working properly ,but still working the heat transfer poor ,probably need to disassemble and actually manually clean heater unit with wire brush till really clean,otherwise replace heater unit as heaters are usually fully sealed. get on line and search for Delonghi magnifica 3300 (parts diagram , replacement parts,parts). then you will have part no and hopefully someone who can supply parts.As for frother if water not heating to enough to make hot coffee the not heating enough to make steam either so frother does not work,if blocked then need to clean out frother tube.
Sep 07, 2014 | DeLonghi Esclusivo Magnifica ESAM3300...
Descale eam3400 delonghi magnifica machine
Hi, you need to select descale procedure from menu options and then add descale solution usually 100-125ml to 1l of water to your tank. Also you should find this how to do in instruction manual.
Jun 28, 2014 | DeLonghi EAM3500 Espresso Machine/Coffee...
Magnifica ESAM 3500 milk temperature low
This is factory preset and cannot be altered. You do need to use the "clean" function on the milk frother unit to ensure the boiler and pipes heat up enough also.
May 15, 2014 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Magnifica 3500.. error message says "grind too fine, adjust grinder, insert water spout, press ok" message never goes away. I called the Customer service.. she said try again.. to...
Try removing the beans from the hopper and use a vacuum to CLEAR/REMOVE any grounds and then adjust the grinder 4 clicks clockwise. If this works Re-adjust grinder to where you get nice crema.
You can try using all ready ground coffee by following the instructions in your manual (if you don't have a manual let me know) to test it.
Jan 12, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi magnifica rapid cappuccino model EAM 3400.S KEEPS SAYING INSERT THE INFUSER, I HAVE PUT THE INFUSER IN AND IT HAS CLICKED BUT IS STILLS SAYS INSERT THE INFUSER
try cleaning any old bean dust ect with vacuum ... refit or replace infuser lot better . if still no good you need someone to check pcb assy ... bsc appliances 07779933829 we cover repair service anywere via post.
Nov 28, 2010 | DeLonghi EAM3400 Espresso Machine
Delonghi Magnifica After heating up, Unit kicks off and readout says "insert brewing unit", Tried cleaning no result
Husband suggests that could be coming broken off the brewing unit as it should be activating, He suggests you should get in contact with your local De'Longhi Service Centre (should be info on how to contact in your User Manual, or google De'Longhi for your country).
May 18, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
I'm getting the "generic alarm message even though I've cleaned my DeLonghi Magnifica. What do I need to do next?
Not good; from page 21 of the owner's manual: If the message is still displayed after cleaning, contact the service center.
The good news is that when I had to send in my ESAM3500 for warranty repair, I called DeLonghi (1-866-528-8323) and got through to their repair center without difficulty. They sent a new shipping box and wrapping material, and a prepaid shipping label to a repair center about 100 miles away. I got my repair ESAM back in just a week. I hope that your experience goes as well. If it's out of warranty, though, it could be expensive.
May 17, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
79 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
