Question about Rival IR600 Iron
I do not know how to fill with water - Rival IR600 Iron
How do you know when a maestro 70 iron has enough water when filling
Water will no longer enter the fill port when it's full.
May 04, 2017 | Irons
My steampress 660 is has black stuff coming out
Hi Beverly. The "dried stuff" is scale which occurs naturally in tap water. You should always use DISTILLED water - buy litre bottles (approx.$2.ea Home Brand) all supermarkets. Electricity off, empty out all the water in your iron. Half fill with distilled water, cover the filling hole, and shake water inside iron side to side, up and down, vigorously, empty distilled water out and watch carefully to see if water runs clear or has sediment coming out - may need to repeat this action. When water runs clear re-fill iron as normal with distilled water. Put iron on lowest STEAM setting, LIFT up iron but with soleplate facing down onto an old rag/towel (brown water may come out) press steam button on & off to try & clear the holes. Turn iron off, allow to cool. Thick cloth wipe soleplate over getting into the holes if they have not cleared. Triple wrap a wooden skewer in cloth soaked in white viegar or "scale remover" and circulate it around the blocked holes. Go very carefully do not scratch the coating on the soleplate or holes - very important. Let us all know how this goes please and if I have been of help, do hope so. Good luck, Chris
Feb 12, 2015 | Irons
How do I know when my IR4500SC iron has enough water as it is filled sitting flat?
Fill then stand it up to view the fill level. Unless you see a warning I doubt you can overfill it. Just top off the tank and go.
Nov 10, 2014 | Irons
Cloudy water tank. can't tell when it is full
fill it with a solution of distilled water and white vinegar and let it soak for 24 hours. Then rinse it out a few times with distilled water and only use distilled water going forward.
Mar 29, 2014 | Rowenta Powerglide DM253 Iron
We have found an old iron in a new condition but don't know how to fill it with water
download the owner from www.fitness.manualsonline.com or
www. manualsonline.com
see the video+diagrams attached and follow it.
Feb 06, 2013 | Irons
Hi floyd, a friend of nime gave me a steamer and i dont know how to work it i dont know see where you put the water in at.i need to know step by step instrutions on how to work it.
what brand? what does it look like? should be a heavy screw-on cap on water tank. Fill with soft or distilled water, power on, and should be a red light that comes on when hot enough for steam
May 14, 2012 | Rowenta Commercial Garment Steamer - White
A stink bug climbed in the water chamber and we can't get it out. is there a solution?
Slowly fill the water tank with water. The stink bug should rise to the surface. Continue filling slowly and the flow of the water out of the fill hole should force the stink bug out! Remember as you're filling you must use something that will NOT block the fill hole or the water cannot drain and your "little friend" won't be able to be flushed out by the flow of the water.
I hope this helps!
Mar 07, 2011 | Rowenta Professional DX8800 Iron
Where the heck do you fill the iron with water???
Usually there is a fill hole on the front of the iron. Place the iron in the upright position. Pour water directly into the hole and see the water level in the tank rise. Since I don't know which model you have, I can only give you generic instructions.
Aug 21, 2009 | Irons
Water in iron box
Yes... you can use it dry...
Cleaning a Steam Iron White Scale and Brown Water
http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown
heatman101
Aug 15, 2008 | Panasonic Cordless Steam Iron - White/Aqua
Mold
First with the iron cold fill the reservoir with white vinegar.  I would let this sit for a few hours and then pour the vinegar out of the iron. I would do this a couple of times until you see the mold is removed from reservoir. Next fill again with vinegar and run the iron on the steam setting, steaming a clean rag or towel until all of the vinegar is steamed out of the reservoir.  The vinegar will also remove any mineral deposits built up in the iron.
Next rinse the reservoir by filling it with water and emptying it completely a few times.  Follow this by filling it completely with water again and setting the iron to steam setting.  Use another clean rag or towel and steam it until all of the water has been steamed out of the reservoir.
In the future make sure to completely empty your iron after every use to prevent mineral build up and mold growth
Aug 04, 2008 | Rowenta Perfect Iron
Rival IR600 Iron Logo
26 people viewed this question
Top Rival Irons Experts
ray gallant
Are you a Rival Iron Expert? Answer questions, earn points and help others
