Question about Sony Handycam DCR-DVD305 DVD Camcorder
When I try to view my clips and try to touch the touch screen it does not work.
    Problem Solver:
  • 12 Answers
Did you try if it works with Remote Control that comes with the Camera?, if it works, then the problem is the flexible cable that connects the LCD with the main board.
Posted on Sep 07, 2010
Touch screen not working
Try this first if it does not work you need a new screen/control panel.
1,. Take a paper clip with machine on and stick it in the tiny hole on the right side of the control panel the screen will change when you see the screen with copiers and computer look under the computer on left side of the screen see a small dot. when it shows press the "3" key go touch panel adjust follow the screen see if that reset the screen if not need a new one.
Feb 07, 2014 | Minolta bizhub 200 Copier
Touch screen tidak berfungsi
About only thing you can do is replace. but try this
Get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. select touch panel adj. if that does not work get a new panel try web site below as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Nov 27, 2013 | Minolta DiALTA DI2510F All-In-One Laser...
The touch screen does not respond to touch
C350,351,450,252,352..: remove the panel, try carefully moving and reseating the ribbon cables.. the 4 wire one is your best shot..: by pulling up on the black locking slider with your fingernails, them moving the ribbon a bit , reseat it and while holding it in, push the black lock back in.. The larger ribbon has a very delicate brown clip that can be judiciously un-clipped by pulling it up at the center with (again) your fingernail !!gently!! follow the above steps and while holding the ribbon in, re-clip the brown lock. 10-20% chance this will work.. if not, the touch screen (now modified) need replacing.
Oct 19, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
What to do? touch screen just stopped working? worked, and then 30 minutes later nothing...turned off/on several times, can't enter PIN or push "view map".
Try to remove the battery and re insert it back in to see if it will work. Or hold down the power on/off for about 15 seconds, that should do the job.
If that does not do it, then calibrate the screen, to calibrate the screen, follow the steps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi.
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears(white screen with touch dot),
  5. Then follow the on screen instructions.
That should do the job for you. hope this helps.
Dec 24, 2010 | Garmin nuvi 255W GPS Receiver
Touch screen on lg view does not work
This is a common problem with the LG2_bing.gif VU
Take a look at the following link for videos about taking out the touch screen and how to put the touch screen digitizer back in the LG2_bing.gif CU920.
Remove and Replace Touch Screen on LG VU Cu920
Jun 05, 2010 | LG Vu CU920 Cellular Phone
I have a magellan GPS 4250. after the system boots up, the touch screen is inoperable. It stays stagnant on one view and that is it. What can be done? Thanks
Have you tried resetting it by inserted a paper clip into the reset hole on the side? Unfortunately if that does not work you are pretty much out of luck.
Mar 25, 2010 | Magellan GPS
Not working
open the back side of the ds.you need to use a tri wing screw remover.then remove the screen by carefully lifting the small plastic clip that hugs the ribbon wire,then use a cotton buds to clean the contact of the screen as well as the touch screen.put it back altogether after and try.hope this one helps
Dec 15, 2008 | Nintendo DS Console
DS Lite touch screen
You'll need a tri-wing screwdriver, a small cross head screwdriver a new touch screen and a lot of patience.
1) Remove the screws from the botom case, 3 tri-wing, 3 cross head and the battery cover and battery.
2) Carefully split the bottom case and remove.
3) Open the clip that clamps the touchscreen cable from the back of the connector with a small screwdriver, just carefully lever up the back edge.
4) Carefully part the botom screen from the touchscreen.
5) Attach the new touchscreen to the bottom screen.
6) Re attach the ribbon cable to the clip.
7) Carefully refit the bottom case taking care not to break the power switch.
8) Re fit the screws.
HTH
Mar 01, 2008 | Nintendo DS Lite Console
Sony Handycam DCR-DVD305 DVD Camcorder Logo
103 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
