Question about Amcor 3900 GPS Receiver
Will super glue attach the suction cup to the holder for mounting on a car window?
    President:
  • 1,851 Answers
Well it sure will - then your will not be able to get it off without some real luck - at least not breaking it.
Posted on May 05, 2010
Tip
How to repair/reuse plastic suction cups Plastic suction cups are used in many...
<p>How to repair/reuse plastic suction cups<br /> <p>Plastic suction cups are used in many applications to hold things to hard smooth surfaces like glass, ceramic, laminate, metal, plastic, etc. With time the suction cups loose their holding (suction) strength due to hardening or deterioration. Before trashing and/or spending cash try this if you want a permanent or lasting installation. <br /> <p><span><span>1.<span> </span></span></span>Place the item in the position you want it to remain installed. Make matching marks to ensure that is were you want the item installed. Mark a dot in the center were the suction cup is to hold.<br /> <p><span><span>2.<span> </span></span></span>Clean the old suction cup suction face and mating surface thoroughly, ensure there is not grease or contaminants.<br /> <p><span><span>3.<span> </span></span></span>Apply a thin coat of urethane base all purpose adhesive such as UHU, Liquid Nails, etc. to the suction face and mating surface (do not use cyanoacrilates such as Super Glue or water based glues, they are too hard or too weak for the job).<br /> <p><span><span>4.<span> </span></span></span>Wait approximately 15-30 seconds for the adhesive dry to touch and press or install the item with suction cups at the desired location using your matching marks as guides. Keep the pressure for a few seconds to ensure good bonding. Once installed wait for at least six hours for the adhesive to completely dry, before loading or applying weight to your item if it is a hanger or shelve.<br /> <p><span><span>5.<span> </span></span></span>This should do the trick. If you need to disassemble your item in the future you may peel the suction cups gently using a scraper tool.
on Jan 05, 2011 | Home
My mount at the back of my Tom Tom does not stay secure and also the suction cup is not so good. How do I secure this? Thank you
This is pretty common and a regular aftermarket universal one is my recommendation to you.
Another issue is that the screen in the area you want to attach must be super clean. I use isopropynol to clean the area and the back of the suction cup only then do I wet it slightly with clean water (don't lick it LOL)
These cups are also subject to suction failure in large temperature swings (I live in Canada so I can tell you about those)
The after market ones do seem better from personal experience.
Bob
Aug 18, 2010 | GPS
There is a black disc but I do not see any instructions for using it.Does it mount on the windshield?
my Magellen came with a black disk with adhesive on 1 side. Intended to be adhered to any smooth surface (e.g., windshield). The mount for my unit includes a suction cup. So, mount black disk to windshield and attach suction cup to smooth side of black disk. Be sure disk is positioned where suction cup and bracket and GPS will have sufficient room to mount everything.
Jun 05, 2009 | Garmin nuvi 255W GPS Receiver
Tom tom gps adhesive plate
Use an 'alcowipe' available from your local chemist.
The alcohol in the wipe will disolve the glue and will not affect your windscreen.
Aternatively get a bottle of 'Spirit Alcohol', also available from the chemists and use a cloth to dissolve the glue
Feb 25, 2009 | Tomtom XL 330 Car GPS Receiver
Windshield Mounting Unmounting
first the round plate... that has a sticky circle on the bottom.... you remove the tape and stick it on a surface where you want the gps... then when you want to mount the gps you suction cup it to that disk. now for the suction cup... when it is disengaged the plastic suction cup will be loose. to attach it to the plate or window... you swing the small arm on the base of it up or down... you will see as it will lock the suction... the gps should clip onto the holder so you can leave the holder where it is and remove the gps and slip it into your pocket.
Not the best instructions but you will get the idea
Robert
Please take a moment to rate this solution thanks
Jan 24, 2009 | Tomtom XL 330 Car GPS Receiver
How to mount tomtom 125 to the car
Alcohol works to a great degree to clean some surfaces. I have used lighter fluid to dissolve glue or adhesive residue that may exist. The alcohol will not work on a poorly cleaned surface. And lighter fluid does not seem to harm plastics. Use sparingly and clean in two or three apps.
Your solution seems to be that you are trying to attach the GPS suction cup to the dash without the plastic disc that comes with the unit. Glue the disc onto as flat a part of the dash as possible, Prefferably on the top of the dash. Then attach the Tom Tom with the cup onto the disc. A slight downward pressure while turning the locking handle is all that is necessary. I had a momentary adjustment time to learn how to lock mine. Love the TomTom GPS compared to the Navigon I returned to get an
XL330 S.
Dec 21, 2008 | Tomtom ONE GPS Receiver
LG GPS not suctioning to windhield
You must clean the window area using windex, or other cleaner, and wipe until dry. A clean winshield area provides the best suction, from the mounting bracket.
Slide the mounting bracket switch to Off & On a few times, make sure the suction cup is able to move(slightly) and that the small tap is facing the area with the notch in the metal.
After putting the switch to the middle, moisten the suction cup slightly
(saliva works bestter than water for some reason)
press it to the window with a slight amount of pressure
then move the switch, (Which should be set to Center!)
to lock it on firmly.
If this doesn't work, then there is a good chance the suction cup has become hardened by the sun. If that is the situation, you'll have to contact LG
(or a place that sells "knock off" brackets to get a replacement.)
I never leave my LG GPS in the car, when not in use. Even the bracket comes out, as I've seen what the sun can do to damage those plastic suction cups, fortunately, I learned it on a $5 replacement set for a Radar detector/Emergency Vehicle Alert device, and not a more expensive bracket.
Dec 07, 2008 | LG LN740 GPS
Suction cup problem
Make sure your windshield and the bottom of the suction cup is clean. Clean it with some warter & detergent and wipe dry. Try wetting the bottom of the suction cup before applying it to the window.
I recommend not using the window mount. I recommend using the dash friction mount. You take the risk of cracking your LCD screen when it falls.
1. The dash friction mount will not fall.
2. It's easily removable/
3. It's legal in all 50 states (window mount is not).
- Jim
Nov 05, 2008 | Garmin nuvi 350 GPS Receiver
I have two NUVI 660's and one 360 (?) navigation systems. They all work great except all three have the same problem with the suction cup. Aftera few months, they will not stay attached to the...
Hello rkfowler,
While the suction cup mounts included with most GPS units are very effective, they certainly can fail. It sounds like you are doing everything you can to make it work: cleaning both the windshield and the cup itself. You also might try putting a few drops of water onto the suction cup before affixing it.
If the suction cup mounts aren't working out for you, Garmin does have a couple of other options including a vehicle mount that uses a super strong adhesive or a friction style mount. These are available from Garmin directly on their website (www.Garmin.com) or through your local consumer electronics store, such as Best Buy.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 08, 2008 | Garmin Nuvi 660 GPS Receiver
Amcor 3900 GPS Receiver Logo
126 people viewed this question
Top Amcor GPS Experts
Will Halftowaite
Martin Murray
Are you an Amcor GPS Expert? Answer questions, earn points and help others
