Have a gateway dx-4300 desktop computer with hdmi. I want to show my powerpoint presentation using the hdmi cable to hook up to my tv. Currently with the hdmi cable plugged in to both the tv and the computer it does not show the powerpoint. How do I fix this? ati radeon h4650 is the videocard installed.
  • 249 Answers
Hi!
Right click the desktop. Go to Catalyst Control Center. Select the Displays Manager Tab and then click the Wizard. Just follow the steps and make sure that you choose Clone (Presentation) Mode.
I hope this helps.
Jubert
Posted on May 05, 2010
Gateway lx6200 plugged in vga and hdmi cables to various monitors and no video on startup
Is the video card any good? Chances that all three monitors are defective are slim.
Mar 15, 2014 | Gateway LX6200-01 Phenom X4 9500 8GB DDR2...
Gateway Dx 4300 - black screen and message "No signal RGB"
soumds to me that a setting has been changed on the monitor itself. play around with those and im sure you will find a fix keep RGB in mind
Jan 31, 2013 | Computers & Internet
Hdmi hook up for insigna tv currently on cable
Using a HDMI cable connect the two devices.
Jun 11, 2012 | Televison & Video
I cant run my gateway GT5676 pc in normal mode with Samsung TV / Monitor
If I'm understand you correctly you said you have the HDMI Cable and the VGA Cable comming from the Computer to the TV. You should only have one cable. Either use the HDMI from the computer to the HDMI to the TV or use the VGA from the Computer to the VGA on the TV. Once you have the cable connect select your input on the TV. If you have the VGA Cable connected your input to select on the tv will probably be PC or Computer. If you use the HDMI Cable your input to select on the TV will be HDMI.
One you connect the cables and select the input try rebooting the computer and the video might show up automatically on the tv. If not you will have to hit the FN (Function key) + the correct (F1 thru F12) key that corresponds to the external display. The correct key will probably have CRT/LCD on it or it might have the icon of a display. Press and Hold the FN key then hit the correct key (F1 thru F12) that toggles the display. The display will toggle on 3 setups (Computer only, TV only, both the TV and Computer).
Now as for not being able to boot up normally that's another issue.
Apr 06, 2012 | Computers & Internet
How do i run my computer to my tv. I hooked it up through HDMI and it shows my background but nothing else.
Your monitor and your TV are currently screen 1 and screen 2 with screen 2 as an extension of screen 1 (you can move your mouse all the way across and see it come over to the TV screen). With Vista or Windows 7, right click on the desktop (no icons or programs) and choose Screen Resolution. There you will find options to change your screen output. (The choices are fairly straight forward - both screens identical, screen 1 or screen 2.) For XP, the right click on the desktop will get you to the point but I think it was called Display Options.
I hope this helps.
Apr 04, 2010 | Gateway Computers & Internet
How do you hook up the tv thru dvi out with a sony pcv-rs620g
There are several ways to do this. The two best are:
1. Get a DVI to HDMI cable. This will allow you to plug directly from your computers DVI to your TV's HDMI.
2. If your computer has an analog (rgb (vga) 15 pin) input, you can simply get a dvi to vga adapter and plug into that port.
Currently, I am using option 2 for my own use.
In the photo below, I point out the HDMI, RGB (VGA), and audio inputs. You must use the audio input but you have a choice of using the HDMI or RGB for video input from your PC. If you have the extra HDMI slots, I would use that. If not, the RGB is fine.
Mar 05, 2010 | Sony PCV-RS620G PC Desktop
Connect laptop(with HDMI output) to TV( with s-video input)? Hi I have a laptop in which there is port for HDMI output and TV with S-Video input. I bought a cable (HDMI HDTV to VGA HD15 Y/Pb/Pr 3 RCA...
Here how you can connect a computer running windows vista to projector or other external display.
  1. Open Personalization window by right clicking on empty desktop and choose "Personalize",
  2. In the Tasks list click on "Connect to a projector or other external display" link,
  3. The Windows Mobility Center appears, in the presentation settings box click the turn on button to turn on projector,
  4. Now your screen will show up on projector screen around large display as well as your own computer screen,
  5. If you want to change the presentation options click the Projector icon inside presentation setting box,
  6. The Presentation Settings Windows appears, if you turned on the projector the "I am currently giving a presentation" checkbox is selected,
  7. When you are giving a presentation your computer stays awake, system notification are turned off and by default the screensaver is turned off,
  8. You can also set the system volume to show different windows wallpaper in the one you usually use, when the presentation ends and you turn off the projector your regular desktop wallpapers returns,
  9. If you are not sure what displays are connected click "Connected displays..." button on bottom of existing window.
Jan 10, 2010 | Office Equipment & Supplies
I have horizontal lines on my Mitsubishi 62525 dlp tv. it does this on cable and component sources (only ones i have hooked up). When you pull up the tv menu these lines do not appear and also the lines...
Bad capacitors. On my set HDMI looks clear, but component inputs have moving horizontal lines. There's a guy named Tbully on AVS forum that did a PowerPoint presentation that will point you to the capacitors to change. Sorry I don't have a link at this time.
Oct 07, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
