Question about Garden
I want to change the fuel filter on my weedwacker
How do I change the fuel filter on my weedwacker ?
    Sniper:
  • 52 Answers
The fuel filter is in the fuel tank. Before removing make a sketch of where the fuel lines connect to. Empty the tank and use a flash light and look inside the fuel tank to see which line has the filter on it. There's a retainer on the fuel line up against the fuel tank on the outside. Use a small screwdriver to remove this retainer. It looks like a washer. Remove the fuel line from the carburetor and using needle nose pliers pull on the old filter and remove it from the filler hold with the fuel line still connected. You should use a new fuel line the same diameter as the old one. From the outside feed the fuel line through the hole. It will be tight. Push it through until you can get a hold of it through the filler hold. Put the filter on then pull the fuel line back. Pull until the filter is up against the fuel tank. Put the retainer on the line and while pulling the fuel line tight press the retainer up against the tank. Attach the end of the fuel line back on the carb.
Posted on May 05, 2010
3 Suggested Answers
digritz
  • 530 Answers
SOURCE: craftsman 32cc would not idle
If you are certain that you have correcting gaped the plug then the next step is to readjust the low end idle carburetor. If you look you should see two holes in the plastic cover that lead to the flow adjustment screws they may even be out in the open. If they are not labeled H and L (the L is the one you want), check your manual for the correct one. A good place to start is turning the screw all the way in then backing it out 1 1\2 turns. Then check it. If you still have problems do 1\4 turns out. After about one full turn from that you might want to consider taking the carburetor off and removing the float bowl or the bottom for a good cleaning. A sticking float could cause problems with your fuel flow.
Hope this helps.
Posted on Sep 03, 2009
rycgl
  • 1545 Answers
SOURCE: RE: craftsman weed wacker
The air filter is a piece of cake... it is inside the middle cover which comes right off....The fuel filter is a different animal and is located IN the fuel tank at the end of the smaller diameter fuel line which comes out of the tank and goes directly to the body of the carburetor...your problem could be something else entirely though...like worn carb parts...partially clogged muffler and/or arrestor screen or port. These engine produce a by-product of carbon because of the amount of oil they burn along with the gas. It's good that it at least starts but I am leaning towards a problem with fuel delivery here. Drain the fuel tank... Look inside it and check condition of fuel filter...sometimes they break/rot off of the fuel line in the tank and the fuel lines should ALL be replaced at that point.
Posted on Jul 10, 2010
Why does it keep running out of fuel?
needs new gas lines and carb,go to ebay and get them it is about 25 bucks,or you can rebuild the carb and buy a new line and fuel filter,ethanol kills weed eaters,use non ethanol gas from a marina
Jul 11, 2015 | Craftsman 27cc 2Cycle Full Crank Curved...
My craftsman weedwacker 27cc curved shaft wont start and cant figure it out
I need to ask. Did you leave fuel mix in it for a long time? If so then the carburetor will need to be cleaned with a special cleaner. and not the spray can stuff.
Nov 24, 2014 | Craftsman 27cc 2Cycle Full Crank Curved...
Can't get weedwacker to pickup fuel to carb.
check the fuel filter on the end of the pickup pipe in the tank this was the problem on mine also blow the pipe through from the carb end back to the tank then should be ok
May 22, 2014 | Craftsman 27cc 2 Cycle Crank Straight...
Managemylife com
1.You have to remove the air filter *** cover.
2.Remove air filter.
3.Remove 2 screws, to remove the rest of air filter ***.
4.Remove the 2 fuel lines with a long nose plier.(Take a photo of
the position of fuel lines or mark fuel lines for reassembly)
5.Unhook the throttle cable.
Now to fix the Carburettor
1.Remove the 4 screws on primer bulp side of the carburettor.
2.Open the carburettor and clean with paint brush and clean fuel.
3.Replace diaframe kit(available from your nearest dealer) and reassemble the trimmer.
Dec 30, 2013 | Craftsman WeedWacker Gas Trimmer 29cc...
Troy built weedwacker wont start
Try draining the fuel and re filling with fresh, if no better, does it have a spark at the plug? does the plug get wet with fuel? if not try replacing the fuel filter in the fuel tank.
Feb 16, 2012 | Garden
I have a Craftsman's Gasoline Weedwacker model 358.791580. The weedwacker wouldn't start after priming and choking. I observed the fuel filter inside the gas tank unattached because the fuel l
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, oo
Jan 18, 2012 | Garden
Weedwacker won't start
Is there an air lock in the line. Remove the lines and insert only one at a time and see if one will take fuel and the other none? Also, check carb float to make sure its not stuck open intaking fuel constantly flooding bowl
May 31, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman weedwacker keeps dying
If the weedwacker runs OK on 1/2 choke or even better on full choke then most likely the cause is the carb gaskets are stiff and can no longer pump the fuel. Of course make sure the fuel lines are are the right ports (return and supply). While you have the carb apart clean all of the passages with carb cleaner.
Apr 16, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
345 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
