Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
Fisher Paykel Dishwasher drawer not draining water.... F1 error... Drawer is holding water......possible hard water build-up...
  • Fisher and P... Master
  • 713 Answers
F1 means that your machine has activated the flood switch. check the drain hose that is connected to the sink pipe is not blocked. remove clip holding hose to pipe, put end of hose into a bucket and turn on cycle. it should start draining straight away. if it does drain into bucket stop cycle and clean nossel of sink pipe with a small screwdriver. then refit hose and turn on cycle. if it doesnt drain into bucket please reply and i will guide you thru how to check to see if you roto motor is jammed or faulty.good luck
Posted on May 06, 2010
Testimonial: "I have not tried your suggestion,but will tonight...Thanks for the fast reply....let you know how it goes...Thanks "
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 has come up
This video explains how to repair this issue
Feb 21, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
What does an F1 erroor message mean. I have a
F1 means "flood. there is a flood sensor underneath the drawer, and if there is any water under the drawer the control will show that error. Check the drain hose linkage for cracks. Remove drawer and dry the area underneath.
Jul 14, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
F1 error
Not sure if you are getting the F1 error in both drawers or just one.
This is a result of flood switch activating and is due to water getting under the drawer into the housing. Turn the power off at the mains and pull the drawer out as much as possible. Take a few towels and dry the base of the housing under the drawer. Use hair dryer if possible. Wait for an hour or so to make sure the flood switch is dry. Turn on the dishwasher. Do this in both drawers if necessary.
Reason for this is either too much foam in detergent or leaky drain hose or water getting from leaky drawer gasket.
Jun 21, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My Fisher Paykel dishwasher is flashing F1 - top drawer only. The bottom drawer is working just fine.
F1 error means the flood switch in the drawer is activated. If there is water inside when you open the drawer then you will have to manually empty it with a small container.
Most likely the solenoid that controls inlet water is faulty or the water level sensor is faulty.
Try turning the mains power and water off and on again and run dishwasher. If fault persists then you may have replace the parts.
Nov 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Fisher Paykel F1 error / double dishwasher drawer
F1-water on bottom of dishwasher. Uselly it cost by broken drain hose. Need expert tech to fix the problem.
Dec 01, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel dishwasher
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin.
If a flood condition is detected, both draws will activate the drain motors and flash F1.
Remove the bottom drawer by pulling the lock pins on each lower side corner. Slide down and remove front cover. Release the drawer slide clips and remove drawer then dry the catch basin.
There are three possible scenarios for this error code;
1. Defective lid motor(s)...Each drawer has two lid motors, attached to the cabinet on either side of the drawer, that pull the lid tight to the drawer when the cycle is started. (this was very common on early models)
2. Something too tall was placed in the drawer preventing the lid from closing completely.
3. (only seen this once) the drain hose developed a crack causing water to leak only when draining.
Jul 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel dd-603ss
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin. If a flood condition is detected, both draws will activate the drain motors and flash F1. Remove the bottom drawer and dry the catch basin.
There are three possible scenarios; 1. Defective lid motor(s)...Each drawer has two lid motors that pull the lid tight to the drawer when the cycle is started. (this was very common on early models) 2. Something too tall was placed in the drawer preventing the lid from closing completely. OR 3. (only seen this once) the drain hose developed a crack causing water to leak only when draining. Hope this helps....
Jun 06, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dish drawer leaks
The f1 is a flood error. There is a sensor in the bottom reading water. You have to dry it out before you can do anything or the drain pump will just keep running. Check the lid of the drawer you where using to see if anything may have been holding it up or if the seal is torn. If that looks ok you will have to check the lid actuators to see if one is not working. I would replace both right and left if one is out.
May 15, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
863 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
