Download pictures is a broad term. Do you mean send a MMS message to a contact or take pictures from your computer and send them from the phone. If you want to send a MMS(picture message) to people, simply create a new message and add a picture. If you want to put pictures on your phone, connect it with a cable to your computer or you can put them on your sd card as well.
Try emailing the pictures to yourself by putting your email into the place where you put the phone numbers. Try connecting the phone to the computer if it is possible. If you do have a cord, go to my computer and it should show that it is connected. From there, navigate the files in the phone and try to find the pictures.
ok the first thing to do is find out is , is it the phone or the memory card, so try another memory card. with a bit of luck it will be the card that is unstable. if its not the try updating the the firmware on your phone but do it using the pc suite that maches your phone and backup your entire phone contacts pics etc to your computer. now dowload and install the update usually the pc suite will do this for you. i hope that helps.
1st, you'll have to transfer your pictures from your phone to your computer. If your pictures are on a memory card, take your memory card out, put it in the adapter that came with it and put it in the slot on the side of the computer. Some options will pop up and you'll want to "save these pictures to a folder". Save them in the location of "My pictures" and name them something you'll remember. After that, put your cd in your computer and you can save them onto a cd!
The easiest way is to put the phone's memory card in the PC's card reade and place pics in the image folder on the card. BUT, beware that the phone can read only upto a certain resolution. If your pics on the computer are of greater resolution than that then the phone will not be able to read them.
put your memory card in the computer as if you were going to put the picutres on your computer and save them then clear your memory card and then take them from the computer adn put them on your memory card adn then save all pictures from memory card to phone and then clear memory card again and then place in computer defrag memory card and then put all pictures back on and then place in phone move all picutres to the memory card and then you will have two of each picture then delete them to where you only have one of each and then it is fixed
you can solve this problem bij putting the pictures first on your computer, than put them true the program of the other phone you want to put the picture on ,than put the pictures on yuor phone with the progam of hte phone
