Question about ViewSonic VP201s 20.1" LCD Monitor
My Viewsonic VP201s monitor is hooked up as a second monitor off my laptop. I can no longer view anything on it. It appears to be flickering at a high speed. However the laptop screen is fine. It seemed to happen when my screen saver didn't kick in and i came back in the room to discover this a couple hours later.
  • 80 Answers
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
Posted on May 15, 2010
Driverswont load for my viewsonic vp201s monitor
Call ViewSonic Technical support to resolve your issue.
Oct 11, 2014 | ViewSonic VP201s 20.1" LCD Monitor
Viewsonic VA1918wm-2 VS12085 intermitent display
If you have not updated the graph drivers, and it has been working, then you should contact View-sonic, go to their website, check warranty, but if you didn't change anything, it should be the monitor having problems. Did you check the plugs on the PC and monitor, the power plug on the monitor, make sure they are connected right and didn't come lose.
Mar 31, 2013 | Computers & Internet
VG150B says out of range when I hook up to my laptop and will not display anything
You laptop screen can handle higher resolution than this VIEWSONIC, which can only handle 1024 x 768 @60Hz, you need to lower your PC resolution.
http://s807.photobucket.com/home/budm/allalbums
May 13, 2010 | ViewSonic VG150B 15" LCD Monitor
Viewsonic VP201s LCD Monitor won't turn on, clicks...Pics incl.
Hello Eric,
If you can post your pictures on our forum at: http://www.ccl-la.com/forum/index.php Please post all of the pictures because we need to see the whole board. The part you are asking about is just a fuse and will not cause the clicking you are talking about. With the picture posted our techs can better assist you in the repair.
CCL_Tech
Corporate Computer
www.ccl-la.com
Mar 14, 2010 | ViewSonic VP201s 20.1" LCD Monitor
We have the monitor hooked to a docking station for a laptop. I can not view the screen on the Viewsonic, but does display on laptop. I have been able to do an extende monitor view, but not the main view....
when you connect external monitor to a laptop u get two options in the monitor section of graphic properties tab
1.) extended
2.) clone
it is clear from ur post that u are using extended view
try using clone mode then both laptop screen and external monitor will show the main screen
other method is to disable the laptop screen and just allow external monitor to work, in this case laptop screen shows nothing but external monitor shows main screen
Sep 29, 2009 | ViewSonic VG700b 17" LCD Monitor
Screen went black
Swap monitor connections to determine if one of the monitors is not working.
If one is not working you probably have an internal problem. If power led responds to the off-on button but no picture is seen, the inverter has likely blown a fuse. Replace the fuse and resolder the leads on all 6 inverter transformers or the fuse might blow again.
Monitor Mike
Mar 27, 2009 | ViewSonic VP201s 20.1" LCD Monitor
Monitor flickering and rolling
Thanks for the git back: #1 I hooked up a second monitor (depressed fn+f5) and was able to view everything fine. No problem in any area. Ran Some security checks (malwarebytes,checked windows updates,Secunia PSI,and a virus scan. #2 I opened up the monitor and checked for possible loose connections. #3 brought up the graphics display and checked that 60 hrz was set and correct. #4 ran a backup of all my data from my other monitor,and I made the assumption that it was a bad monitor and I might save some money if I just bought a new laptop.Would like to here your comments. Sincerely : dandee4u3
Mar 22, 2009 | Acer Aspire 3690-2196 Notebook
Vx900 viewsonic monitor problem . Blank screen except for power off/on
no, Viewsonic has the part for sale 42.99 - free shipping. Easy to replace
May 25, 2007 | ViewSonic VX900 19" Flat Panel LCD Monitor
ViewSonic VP201s 20.1" LCD Monitor Logo
154 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
