Question about Sony Ericsson P990i Cellular Phone
Alarm Goes off
I had set an alarm for 5am 4 mths back for 1 particular day. However since that day the alarm goes off everyday at 5 am and I am unable to find it in the alarm list to switch it off completely.
Please advice.
Thanks
Aks
    President:
  • 1,950 Answers
This is a known bug in the P990 firmware (I personally went crazy from this). You need to update to the latest firmware for this issue to be fixed.
Posted on Mar 26, 2008
SOURCE:
Alarm goes off at 5:00 am everyday
You need to check the manual for the alarm settings menu that allows you to go through the settings and disable the alarm.
Jan 31, 2015 | Cars & Trucks
I need discovery kids tm daisy clock manual
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between month/day/year/hour/minute. If it goes to the alarm setting instead of time setting, try again.
2) set alarm: hold down "alarm set" button for 5 seconds, use up and down arrows to change, press "alarm set" button once to toggle between hour/minute. press "time set" button to return to clock
3) turn on/off alarm: press "alarm set" button once, press "up" to turn alarm on and press "up" again to turn alarm off. press "time set" button to return to clock
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial near the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time)
Good Luck!
Jun 22, 2013 | Toys
Clifford alarm
check the internal battery of the alarm as it may be getting low on charge.
May 30, 2013 | Vehicle Parts & Accessories
Samsung Galaxy S4--Alarm Clock Issue
Take it back and get your money back as there is obviously a problem with that unit. Try a different brand.
May 23, 2013 | Samsung Cell Phones
Samsung Galaxy S4-Alarm Problem
Go to your alarm settings and make sure that the Smart Alarm is off, I know that the smart alarm makes the alarm go off early, this could be possibly be the problem.
May 23, 2013 | Samsung GALAXY S4
Alarm goes off same time everyday
2012--- take it back to the dealer under warrantee
Scan Tool Data is always a year behind the latest model,
if even needed
No point in guessing at that,let the dealer resolve
Nov 19, 2012 | 2012 Dodge Durango SXT 4dr SUV 3.6L V6 FFV...
My fuel pump on my 1997 efi roadking does not sound as loud as usual
Hi Gary, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at "BOTH" ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to on.
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
7. Security alarm not disarming
For a prime suspect please visit website below. Good luck and have nice day. Harley Check Engine Lamp Diagnostics
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 10, 2012 | 2000 Harley Davidson FLHR-FLHRI Road king
T-mobile dash multiple alarms
The solution is a follows; If you have any legit alarms already set, disable them before proceeding
1) As soon as the unwanted alarm goes off , look at what time your phone says it is and make a note of it. (if you know EXACTLY what time it goes off at, then go to the next step)
2) Goto Start -> Clock & Alarm -> Alarm
3) Set the alarm time for the exact time from step #1. Set alarm to On.
4) Click Done, done, and done
5) Goto Start -> Clock & Alarm -> Alarm
6) Change the alarm to Off.
7) Click Done, done, and done
That's it, the alarm should now be disabled for this unwanted alarm, if you have multiple unwanted alarms, repeat this procedure for each.
Dec 11, 2007 | T-Mobile Dash Smartphone
HOW DO I SET THE TIME?
Wildbill,
My wife has the AudioPhase SPR1 AM/FM 2 AAA portable sports type music player. There is no pdf manual available on internet yet - I will scan and post when I get time. The paper manual says:
To set the Clock:
1. Turn unit off.
2. Press MEMORY once: the clock will start flashing.
3. Press DOWN/MIN to set the minutes, press UP/HOUR to set hour.
4. Press MEMORY again to complete time set.
5. There is always an AM/PM indicator on the LCD display to indicate DAY or NIGHTTIME or night.
To Set Alarm:
1. Turn unit off
2. Press ALARM once: the alarm will start flashing.
4. When alarm time setting is complete press MEMORY 3 times.
5. The alarm setting is completed.
6. Now alarm standby is ON. ALARM indicator will now show on the display.
--> Alarm will only make a noise throught the headphones. When it goes off cancel it by pressing ALARM.
Canceling ALARM standy by.
1. Turn unit off.
2. Press ALARM twice.
3. Now ALARM standby is off.
Radio:
To Seek press UP/HOUR or DOWN/MIN to click throught the frequency or press and hold to seek.
Oct 27, 2007 | Griffin Technology SPR1 AM/FM Radio
Sony Ericsson P990i Cellular Phone Logo
80 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
