Question about Toshiba Satellite Pro L300 Notebook
My Toshiba Satellite PRo L300 won't shut down.
If I turn it off or let the battery run flat when it goes back on it still hasn't shut down. Control alt del doesn't work.
    Problem Solver:
  • 17 Answers
SIMPLY REMOVE BATTRY AND POWER SUPPLY
reconnect them
go to power options and check setting
"when i press power button"
select shutdown
Posted on May 05, 2010
Laptop goes on some few minutes after being shut down.
you cannot blame windows xp because according to me it is such OS that it removes many problems of windows 7 and vista.windows 7 and vista makes your pc much slow and many features dont work but windows xp is free from these errors.actually you hear the sound but nothing appears on the screen.this is because your cpu fan is running which takes somes time to stop.may be some problem of the hardware especially the mainboard.go to any repair shop and just get it checked.
Apr 02, 2012 | Toshiba Satellite Pro L300 Notebook
I have a Satellite L300 running Windows 7. I can charge the battery up using the OEM charger that came with the laptop. However, the computer will not operate if the charger is plugged in. I can do...
right off the bat, i would suspect a bad power adapter for the computer. or perhaps a faulty computer. your best bet is to call toshiba and talk to them directly.
Sep 06, 2011 | Toshiba Satellite Pro L300 Notebook
My Toshiba Satellite L300-D won;t get poast Startup Repair page. Keeps defaulting to Startup Repair and then says "Windows cannot automatically repair your computer". It all started with a folder...
Your Hard drive is faulty which means it wont go any further and loops back trying to fix a problem it cant do. you can either replace the hard drive and install everything from scratch or send it in to a computer repair shop to do it for you. Kronoguy
Aug 02, 2011 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite laptop won't wake up from hibernation even after holding power botton down?!
If pressing down and holding the restart/start button doesn't wake it up you might try Control + ALT + DELETE keys (together) - that will reboot it though. And if that won't work then you might have to pull the battery to reset it.
It seems that some laptops have a problem with vista and sleep mode, in particular, and sometimes hibernate too. You can try going under POWER OPTIONS under Control Panel and setting everything back to default, saving it, then resetting it again. Also it's best to avoid using sleep mode if possible to avoid problems.
If the problem developed after a recent install or updating you may need to go to an older store point to fix the problem. Personally, I just avoid using these settings as much as possible and use regular shut down and a screen saver for times when I need to step away from laptop for short periods of time.
Apr 27, 2011 | Toshiba Satellite Pro L300 Notebook
TOSHIBA SATELLITE PRO L300: PSLBDG : PROBLEMS: 1) Restarts automatically when i plug in the power cord. However works fine in Battery. 2) Shuts down when i try to install graphics driver after a clean...
Replace the AC Adapter, (ebay from £10.00).
Did it come with XP on it? Mine came with Vista and there are conflicts with XP and graphic adapters. There is no XP driver for the ATI adapter in mine.
Go online to Toshiba and download all of the updated drivers that you require. A user friendly system.
Dec 22, 2010 | Toshiba Satellite Pro L300 Notebook
When i turn it on it says run recommeded repair or run normal setup then when i run the repair it says hardware or software missing please select ok to shut down and when I run normal set it just goes back...
it's mean your operating system is failure so just do repair or format Ur OS & re install fresh copy of operating system..but take backup ur document before formatting Your OS.
Mar 25, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite L300 Will not start
I have had a this few times... what happens is the Contacts on the Socket for the power supply comes away from the Motherboard. Subsequently, it will not charge, nor power on... & then the battery gets so flat that it stops it all from working... You will have to get it repaired, it is a bit of a mission. & sometimes the damage done to the Motherboard precludes repair. So get a firm "Quote" from a reputable service center/man.
Feb 03, 2010 | Toshiba Satellite Pro L300 Notebook
My toshiba satellite l300-1aq laptop is freezing within minutes of start up? I am running Windows Vista. How can I root cause the issue?
When you power up, turn the notebook so you can see if the cooling fan is running.
It sounds like the self protect shut down from over heating.
Feb 01, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite Pro L300 keeps locking up for no reason. After turning it on for awhile the mouse won't scroll anything or select anything and the only thing I can do is turn off the power and take the...
Open the "Task Manager" by (right ) click in the Statusbar, located in the same (level as the start button). Next see how many Processes are running? If the (number) of processes running are between 75-80, the Computer is running very slow, this could be a ("Low") Memory problem, you can check the "memory usage" in the "Task Manager" as well. Try to "Shut-down Non-essential programs from "start-up."
Jan 22, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite Pro L300 Notebook Logo
184 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
