Question about Frigidaire FWS833A Top Load Washer
Will Not Engage in Spin Cycle
Fills up with water, runs through 16 minute wash cycle, but will not drain water or go into spin cycle. Stops when it reaches spin on timer. We replaced the timer and pump but did not change anything.
    President:
  • 1,554 Answers
The most common cause of a no spin problem is a faulty door/lid lock and switch assembly. It is a safety feature of the washer not to spin or tumble when the door/lid lock is not activated. The washer will tumble for the first few minutes while it is detecting the door/lid switch but will not advance if the switch is not activated. If the washer is indeed a Frigidaire FWS833A Top Load Washer, the lid lock is part number 131675600. Disconnect power to the washer prior to servicing to avoid the risk of electric shock. Begin with the removal of the screws attaching the top panel to the rear of the washer then slide the panel rearward and lift it off the washer. The lid can now be removed and replaced; remove the screws securing it to the cabinet and pull it off. Secure the new lid lock in place and connect the wires. Reinstall the top panel and secure it back in place.
Posted on May 05, 2010
  • Jahn27
    Jahn27 May 05, 2010
    Indicate the make and exact model of the washer if it is other than the one described above.
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
My washer fills and runs tru the washing cycle then stops. It won't go thru any other cycles, won't spin and does not make any noise. Is it the timer?
Does it drain?? If not then you need to replace the pump. The pump drains the water hence allowing the spin cycle to engage. Sorry for the bad news.
Oct 17, 2009 | Washing Machines
Wash cycle and spin
you need to check a simple button called " no spin" may you will see it marked "aspiral shap" and has "x" over
good work !
Jul 05, 2009 | Zanussi ZWF1430W Front Load Washer
Spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
May 21, 2009 | Kenmore Washing Machines
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Will not drain or spin
Unless you jarred the machine it's the timer. You can check this by bypassing the lid switch and seeing if it will cycle.
Dec 13, 2007 | Washing Machines
Frigidaire FWS833A Top Load Washer Logo
130 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
