Question about Neff H5642 Convection / Microwave Oven
Neff H5642 This appliance has a internal niche of 380 high (+2). With a face frame of 388 high. A difference of 8mm, is this equaly spaced ? 4mm at top & 4mm at the bottom. Regards Mark.
    Problem Solver:
  • 9 Answers
Your question is unclear, but you should probably have more door overlap on the front face than 4mm top and bottom. This will be ok if the door fits into a flush frame when
Posted on Apr 04, 2008
Hi, my neff model5642 microwave oven appears to be fully functioning but its not warming up any food at all. What could be faulty. Regrds Brian
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Jan 13, 2011 | Neff H5642 Convection / Microwave Oven
Neff h5642 doesn't start at all. No lights, no display. What should I check first?
safety fuse (internal) will have blown usually caused by faulty inverter short circuit if fuse changed and blows again this is what it will be costly repair if out of guarantee.
Apr 19, 2010 | Neff H5642 Convection / Microwave Oven
Microwave starts as normal but cuts out after
This is happening due to either the magnetron, or the Power Diode, or both, is breaking down, under load, then the unit detects the fault condition, & then, for safety reasons, to avoid a fire or explosion, shuts down the system. You need to take it in to be looked at please obtain a "Quote" before proceeding with any work. This way you can decide to repair or replace.
Mar 24, 2010 | Neff H5642 Convection / Microwave Oven
Neff microwave turns and lights when started but doesn't heat
check on rating plate if fd number starts with a 7 or 8 eg fd 7908 then appliance will need mag leads recrimping they oxidise over time and break connection giving syptoms that you describe, its an easy fix but you need to remove outer casing.
Feb 22, 2010 | Neff H5642 Convection / Microwave Oven
Turntable Doesn't Rotate in Neff H5642 (1000w)
I'm sure your motor has failed.
Sometimes it a broken post inside the motor, if you like to tinker.
Otherwise I would contact Neff's service people for a spare.
Aug 22, 2008 | Neff H5642 Convection / Microwave Oven
Neff H5642 1000 Watt Microwave
Sounds like the Magnetron may have collapsed. Probably not worth repairing. Check for burnt/browned components on circuit board/s. Burnt wires, insect or ant damage or soiling. Magnetron is the large-ish square metal object with lots of heat-sink fins on it. Check for discolouration. If nothing obvious, it's probably stuffed, If something is obvious, it's still stuffed, but it may be
Apr 04, 2008 | Neff H5642 Convection / Microwave Oven
Open door, place hands in centre of roof, lift gently and move back. This reveals four screws that mount the frame to the outside wooden housing, remove these and then remove the frame. Now lift the microwave out of the oven housing.
Dec 14, 2007 | Neff H5642 Convection / Microwave Oven
Neff H5642 Convection / Microwave Oven Logo
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
