Question about HP LaserJet 1320 Printer
Not printing! The red light is flashing next to the triangle with an exclamation mark in it. What does this mean? I have turned the printer on and off again, rebooted my laptop, checked for paperjams, put in a new toner! Why won't it print?! Please help me! [email protected]
  • 2 more comments
  • joejoeblue Mar 26, 2008
    The orange light by the triangle keeps flashing.I re-booted computer, shut off and on the printer,checked connections, no paper jam-PLEASE HELP!!!!!!!!!!!!!!!
  • littlelauraq Mar 27, 2008
    I have done this and there is nothing I can see. Any other suggestions?
  • harus May 19, 2008
    When switched ON, green ligth for TEST PRINT button, the green light above the TEST PRINT button and the amber light at the side of the CAUTION TRIANGLE all come up. Connections, paper jam and catridge were all checked and were all OK.
    Pls help me out, if possible, give me link to get the troubleshooting manual on internet. Thanks.
  • Anonymous Jun 14, 2008
    new cartage and turned off and ba
    ck on
    Genius:
  • 1,913 Answers
Pls open your bakside.and
check there is no any paaper jam in fuser assembly.
Posted on Mar 26, 2008
  • kishor khatri
    kishor khatri Mar 27, 2008
    hi
    try to yaste page from printer .
    if u get print then install your printer driver again.
SOURCE:
There is a red warning triangle with an exclamation mark in the centre on my machine. What does it mean?
If that light flashes, it means that the service door of your coffee machine is open.
If you can't close the service door then probably the infuser is not pushed in far enough.
Hope this helps.
Sep 20, 2015 | DeLonghi Magnifica Super Automatic...
I bought the Polaroid Pogo mobile printer.when I first used it, it worked well.today I tried to use it and it is just not working. My phone seems the picture but the printer gets a red flashing light how...
That depends on which red light is flashing. If the battery light is flashing, that means the battery is exhausted. Fix it by charging the battery.
If the status light is flashing red, that means the paper is jammed. Fix this by opening the paper door and pulling out the media. Full instructions are on page 3 of the manual.
The battery light is the one marked with a battery. The status light is the one marked with an exclamation point inside a triangle.
Feb 12, 2012 | Cameras
What does the button on the the 1320n that has a triangle with an exclamation mark mean? The light next to it is blinking and we don't have a manual.
Attention light is blinking
This state can be reached in the following circumstances:
? Paper tray is empty
? Door open
? Paper jam
? Misfeed from tray
1. Verify that the print cartridge is present and that the print-cartridge door is closed correctly.
2. Verify that media is present in the input tray.
3. Clear any jams and perform paper-path functional checks.
4. Make sure that the interlocks are operating correctly.
To reset the printer after a jam, press the GO button.(Green Button)
Sep 21, 2011 | HP LaserJet 1320n Printer
I am trying to print a document and the Triangle with the Exclamation mark is flashing. What does this indicate?
that means atention:)
Maybe toner is low. Don't worry and keep on printing until you can. But if you can't print then maybe you have a paper jam. Look for problems with paper and restart printer
pifonski
Mar 03, 2011 | HP LaerJet P2015 Laser Printer
Help!! Triangle with exclamation mark is flashing. What does it mean?
The blinking triangle indicates one of the following: Paper tray is empty, Door open, Paper jam, Misfeed from tray.
To fix it:
Verif that the print cartridge is present and that the print-cartridge door is closed correctly. Verify that media is present in the input tray. Clear any jams and perform paper-path functional checks. To reset the printer after a jam, press the Go button. You might need to clear the error manually, and press the Go button or close the top cover
Feb 07, 2011 | HP LaserJet 1320 Printer
New Saeco Odeo Go has solid red exclamation mark, doesn't budge
You have to 'manually' prime the pump: When the red exclamation mark shows, press the water switch on the right side (the picture of the water drip), then open up the steam nozzle and let the machine pump hot water into a cup until the red light goes out.
Jun 11, 2009 | Saeco Odea Go
Light on. Exclamation mark within a triangle. Printing fine and clear. What does tis symbol mean?
This light is indeed designed to indicate a low toner condition. Its coming on is triggered not by the actual level of toner in the cartridge, but by a software process that estimates toner use. If you are inclined to refill your own cartridges, you can use install a glass fuse in the little clip on the back of the toner cartridge that will reset the counter, and turn out the light, otherwise the light will stay on. The reset process will blow the fuse, so a new fuse is needed each time a cartridge is refilled. Leaving the light lit does not hinder the operation of the printer, so as long as there is still sufficient toner to print, the printer will operate normally.
May 21, 2009 | Samsung ML-2510 Laser Printer
Flashing triangular light with the exclamation mark inside it.
Clear the printer queue on the computer (double-click the printer icon in the tray or in the Printers and Faxes folder and cancel all documents listed). Then power off the printer and disconnect the power - remove the paper from the paper tray until you have the printer memory cleared as to not waste paper.
Jan 22, 2009 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
512 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
