Question about Craftsman 10" Table Saw
I have a craftsman 10" table saw model #113.240421. What size and thread pitch is the nut that holds the blade on?
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
  • 15 Answers
SOURCE: truing craftsman table saw blade
Use a carpenter square to allign the blade both vertically and horizontally with your guide. This works very well.
Posted on Jan 28, 2009
  • 59 Answers
SOURCE: old craftsman table saw parts?
most sears stores have a dept. that refurbishes and sells these tools. if it can be had, they can help.
Posted on Apr 25, 2009
  • 384 Answers
SOURCE: key switch on Craftsman table saw
Switch is filled with sawdust. Disassemble and clean out.
Posted on Sep 14, 2009
SOURCE: Wiring diagram for a Sears Craftsman 110/220V motor
I found a local small motor technician who was able to help with the wiring configuration for the 110/220: I had wanted the motor to run on 110V
Posted on Dec 04, 2009
How do you change a blade on model 36-075
Lots of saws have left hand threads on the nut that holds the blade in place. It is designed so that if the saw starts up and the nut isn't snug, the nut and the blade slipping on the turning arbor would tend to tighten the nut as they slip against the force of the spinning arbor.
1. Unplug the saw.
2. Hold on to the blade tightly with one hand.
3. Put the wrench on the arbor nut and turn it in the direction you would turn it as if the wrench were turning the blade to cut wood.
If you've previously overtightened the blade, jamb a piece of wood against the teeth and the saw table top and then follow step 3.
If the motor is on the left side of the blade as you face the saw, then it's a standard right hand nut.
If the motor is on the right side of the blade as you face the saw, then its a left handed nut.
Sep 17, 2014 | Delta Circular Saw Blade, 10 Dia, 50T -...
Having problem get blade off table saw any hints
Unplug the saw, first and foremost.
Then see if your saw arbor has facets for a wrench behind the blade, and if so, try to find a slim wrench that fits there to hold the arbor while you attempt to loosen the arbor nut that holds the blad on. If that doesn't work, take a stick of wood, like a piece about 3/4" x 1 1/4" x 12-16" long, remove the throat plate from around the blade, wedge the stick between the blade teeth and the edge of the throat slot to hold the blade in place firmly, exerting levered force toward the center of the blade to hold it in place, and using the wrench, loosen the arbor nut. Make sure you are attempting to loosen in the correct direction. Depending which side of the blade the nut is on, some nuts are reverse threaded.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 19, 2011 | Craftsman 10" Table Saw
I have a Sears 10 inch bench top table saw. Model 133221770. purchased in 1998. Lost the ''collar blade''. Sears stopped making the part, can I substitute or where can I find one?
If you can measure the arbor size, (the spindle the blade goes on), just buy any collar that will fit. The basic purpose of the collar is to spread out the force over a larger area of the blade from the arbor nut when it is tight.
Jun 08, 2010 | Craftsman Saws
Replacing 10 in blade
Look at the threads on the saw blade arbor, that will tell you which way to turn the nut to get it off.
May 04, 2010 | Craftsman 10" Table Saw
How do I lock the spindle in order to change the blade?
As long as the threads on the arbor and the nut are in good shape, you don't really have to hold the arbor from turning, just the blade. Use a block of wood in front of the blade with the blade raised all of the way. Put the wood down in recess in the table in front of the blade and just pry against the blade. This works almost as well on the back of the blade when you tighten the nut. When you are tightening, the teeth are not pointing to your advantage, but you don't need to tighten the snot out of it.
Jan 25, 2010 | Craftsman 10" Table Saw
Blade becomes loose after 4-5 cuts
Check to see if the arbor, nut or spindle is worn. You may want to get a new shouldered nut for it. Also see if running loose has damaged the shoulder on the spindle. Check that the correct size of arbor is being used on the blade.
Jan 19, 2010 | Craftsman 10" Table Saw
Instructions on how to change out a 10'' blade on a Central Macinery Model 38533 table saw?
table saws usually don't have shaft locks... i either use a piece of wood to hold the blade or a c-clamp. crank the blade all the way up, remove the plate surrounding the blade and put a wrench on the nut,,, hint it is a left handed threading so... its counterclockwise tightens and clockwise loosens.... ps unplug it
Nov 17, 2009 | Saws
Need to change the blade on a craftsman 10'' miter saw model 137.23498, how do i do it?
First off, unplug the saw. No need to remove the guard, though you may have to loosen the cover over the lock nut to access it on some saws.
Look for an arbor lock button on the back side of the blade housing or motor, to lock the blade in place.
Hold that down and use a wrench to loosen the nut holding the blade on.
If you don't have an arbor lock, you'll have to wedge a 1x 4 or 2x4 under the blade and hold pressure on the handle to keep it from spinning while you loosen the lock nut. Once it's loose, spin it off and remove the washer and blade, replace and retighten the nut.
Should be pretty straightforward, as long as you have no power to the machine and lock the blade from turning, not too much can go wrong.
If you want to find an online manual with instructions for your saw, please try Sears online support site at www.managemyhome.com.
May 14, 2009 | Craftsman Saws
How to change blade;where is button to hold blade from moveing
There is no button to lock the arbor on a table saw. One method is to take a piece of wood, about 1" x 1 1/2" x 16" long, rest it against the back or front of the table throat and lever it against the blade, holding the blade from spinning while you use the wrench to loosen the nut on the arbor.
Make sure you first unplug the saw before changing the blade. Lever against other end of throat while tightening.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 04, 2009 | Craftsman 10" Table Saw
Jan 20, 2009 | Craftsman 10" Table Saw
Craftsman 10" Table Saw Logo
109 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
