Question about Britax Verve - Red Umbrella Stroller
Front wheel wont stay on
Its like the front wheel just sets onto a metal rod with nothing to hold it there. Every time we go over a bump it falls off. Did it get assembled wrong? Anyone know whats wrong??
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 20 Answers
Hi
visit www.buggypitstop.co.uk/ they give excellent advice and would be able to fix that for you at a reasonble price.
thanks
Posted on May 05, 2010
Why is my front driver side tire wobble when i hit a bump
First, have the tire inspected before you do any expressway driving. you could have a damaged tire with a tread or internal ply separation. second, inspect the front shock absorbers, it sounds like the left front shock has failed and lost its hydraulic fluid. third have the front steering linkage and front suspension checked for worn or loose tie rods, idler arm, ball joints and stabilizer bar links. do this ASAP as you don't want to have the tire fail or any parts break while you are driving!
Dec 13, 2014 | 1990 Ford F150
2001 grand prix high beams won't stay on
Dimmer switch loose/out of adjustment. Lower steering column gently, find the dimmer actuated witha metal rod. hold the rod in place this is imperitive. Loosen up the switch and tap it up toward the steeringwheel 1/16th an inch at a time untill it works properly. May need to replace the switch, if so just make sure you hold the rod in place with tape or something, because if the rod falls down, you may have to remove the steering wheel to get it back in place.
Dec 15, 2013 | 2001 Pontiac Grand Prix GTP
Three point hitch wont lower, kubota l2550
Mine did the same thing. Below the front of the seat is a knob sticking toward the front of the tractor that is angled upward that controls the fall rate of the three point hitch. After searching the internet for a while I found what this knob is for and went out and turned it until the three point fell down. The knob is perfectly placed to bump with my foot as I get off the tractor (I have large feet and bump a lot of controls getting on and off) and I guess I had bumped it closed over time.
Dave
Jun 22, 2012 | Garden
I recently bought an Amloid My First Mini Cycle for my son. I was only given on packet of assembly intructions for the fork and front wheel of the cycle. Once you put that together the instructions say...
You need to hammer the cap on. The tube with open ends fits over the cap and lets you hammer it on. To make it work, you need something to hold the other end, like a block of wood, or I found a hockey puck worked perfectly. Assemble the rear wheels, then turn the cycle on its side with the cap end of the axle down. Put it on the block of wood or the puck, and then hammer on the cap with the help of the tube. Now if you can help me get the handlebars on, I'd be eternally grateful. Problem is the spacers seem to be too big to allow the fork into the slot in the handlebars, and without them, there is nothing to screw into to hold the handlebars.
Apr 30, 2011 | Toys
My kids have run the wheels down to nothing so I have bought replacement wheels...now I can't figure out how to get them on! The instruction manual is no help as it is just pictures, and not of wheel...
To remove the wheels, start by removing the little black piece in the center of the yellow hubcap. There are a couple of snap tabs in this black piece that hold it in place. When you remove it, you'll see the end of a metal rod going through the center of the wheels. Remove the star-looking washer (easier said than done) and pull the wheel off.
If you're just replacing the wheels, I recommend making sure this rod stays in place during the process. If it comes out, a couple white cylinders fall out of place in the motor assembly area. If they do, you'll need to remove the seat and black cover under the seat to access the cylinders and hold them in place while you push the rod back in place.
Good luck.
Sep 26, 2010 | Peg Perego John Deere Turf Tractor
Front wheels shake when I hit a bump in road
Pitman arm and tie rod ends and bail joints.The three main causes of front end shake after hitting a bump.There's so much slop that when you hit a bump it shakes violently from one end of the slop to the other.Very dangerous!You need to get this fixed now!
Get someone to turn the steering wheel while holding onto a front wheel and just watch for stuff that moves.Turn left and right and you'll see what's the worst for wear.The connections at the steering box arm(Pitman) and at the wheels(Tie rods) will be what moves the worst.Hope this helps?Autozone has a kit for the pitman for $100,probably be $600 at a shop.
Jan 11, 2010 | 1994 Jeep Grand Cherokee
Vibration in steering wheel when a bump or other object in the road is hit
You probably have a worn tie-rod. Jack one side of the car up at a time so that one front wheel is off the ground. Grab the wheel and try to turn it back and forth. You should not feel any play. When you find a wheel with play, reach around the wheel with one hand and grab the inner tie rod and hold it still while pushing and pulling on the wheel. If the play goes away, replace the inner tie rod end. If it does not go away, replace the outer tie rod end.
Oct 02, 2009 | 1995 Land Rover Discovery
Neddle screw wont tighten neddle in
There is a small metal rod about 1/2" long that fits into the hold in front of the screw that holds the needle secure. I didn't realize that I had dropped the rod until I could not tighten the needle. I found the rod, put it into the hole and was able to tighen the needle.
Jun 22, 2009 | Brother XL-5130 Mechanical Sewing Machine
Front in shakes bad
Would suggest getting the rotors machined rather than replaced. After the Thickness variation occurs ,then the metal has already taken it's "set" and will stay true longer.
Rotors are cheap now,but go "out of round quickly"
Nov 16, 2008 | 2002 Chevrolet Impala
Britax Verve - Red Umbrella Stroller Logo
67 people viewed this question
Top Britax Baby Gear Experts
thegtw
CheckitRight
CheckitRight
Jennifer Rock
Jennifer Rock
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
