Question about Maytag 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White
Door seal is very hot
I have a maytag plus msd2356ae and the door seal is very hot. the refridgerator is working fine. I appreciate the help
    President:
  • 949 Answers
This may be a sign of a failed condenser fan or an overly dirty condenser that could lead to problems. Here is a link to instructions I put together on taking care of this. Let me know if this helps.
Thanks.
http://www.fixya.com/support/r4694132-hot_door_seal_rail_divider_strip_between
Posted on May 05, 2010
The refridgerator door is not sealing properly and the magnetic seal between the refrig door and the freexer door is hot.
Heat the seals with a hair dryer and then pull it tight - strap it tightly shut - you can also use some super glue to keep it in place while it dries.
Gary @ Fix Ya
Sep 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer working but refridgerator at room temp. Door seal hot.
either the evaporator coil is iced up which means the defrost heater is bad,the defrost control is bad or the damper vent door which throttles cold air in isn't opening fully from the freezer to refrige,the evaporator fan isn't running or if electronically operated the main board behind the unit can be bad on these as this board controls all electrical issues
Jun 20, 2010 | KitchenAid 19.7 Cu. Ft. Side-By-Side...
Fridge is not cooling
You probably need an adaptive defrost control which is located in the back right hand corner of your fresh food compartment. You have to dismantle the overhead controls to get to it. If you had to defrost your coils, and the heaters test good, then you probably need the above control.
Apr 06, 2009 | Maytag MSD2454G Side by Side Refrigerator
Outside freezer hot and seals
Fridge has either mullion heaters around door or most likely steel pipes just inside the skin of the perimeter of the door, this is to stop ice or condensation forming around the door seals, mainly the freezer, they are part of the condenser circuit ( hot part of the refrigeration system).
It is normal for these to get hot, but in your case may be hotter than usual because of the constant running, the running may be caused by hot ambient temperatures, system being slightly short of refrigerant, faulty thermostat or in-efficient compressor.
I suggest if temp is ok inside fridge dont worry too much, if you notice fridge starts loosing its capacity to refrigerate, have a refrigeration tech look at it.
Nov 13, 2008 | Maytag MSD2756G Side by Side Refrigerator
Space between doors on cabnet is very hot to touch ref seems to work ok
hi. thanks for the question .the heat between the doors is normal . its hot to keep condensation from running down the doors .but pull fridge away from wall. remove back panel and clean all the coils. very important. thanks the appliance doc
Sep 30, 2008 | Maytag 23 cu. ft. Side-by-Side...
Maytag side by side doors hot
hi there,
you may have a clogged vent, preventing air circulation. is there are vent on the bottom by the crispers?
Sep 29, 2008 | Maytag Refrigerators
Maytag 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White Logo
143 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
