Question about Kenmore 53642 / 53644 Side by Side Refrigerator
The door near the strip is warm or a little hot
    President:
  • 949 Answers
Hi, this could be a sign of a dirty condenser or a failed condenser fan motor, see this link for details on this issue and how to resolve it.
http://www.fixya.com/support/r4694132-hot_door_seal_rail_divider_strip_between
Posted on May 05, 2010
Ac don't blow cold only Luke warm and heater don't blow hot only warm what could it be help please
If this is a Ford vehicle it likely is a stripped gear in the blend door motor, which looks like a 4x4" box 1" thick held to the heater plastic box with three or four screws. This part can be ordered online for about $30 and is not difficult to replace on most vehicles.
The wires have a connector that is fairly easy to pinch and pull to release. The little motor box can be unsnapped and opened to view to see if the gear is not engaging or is missing a tooth before ordering the replacement. There will be grease on the gear so have a rag handy to wipe it to be able to inspect for damage. The identical cog gears are extremely difficult to find so don't waste your time trying to replace the little cog that strips out in these.
Mar 14, 2015 | AC Cars & Trucks
When the AC is not on, I am getting hot air blowing out of the vents, Ugh..2005 Hyundai XG350
clairify a/c on cold a/c off warm as in hot like heater hot??
did you loose a pen or something down the defrost vent????
ther is whats called a blend door inside the heater box under the dash
it opens or closes for warm or cold and varies inbetween to give warm .
ther is a motor that controls the door,, have you heard clicking in the dash as u move the temp dial???the lil motor has plastic gears that will strip.or it will just quit. sometimes the heater controler will be faulty itself, start by checking there.. get parts from auto wreckers cheapest way to go!!!
Feb 03, 2012 | Hyundai Motor 2005 XG350
The center wall that runs vertically between the freezer and refrigerator compartment is very hot on the end that is exposed when you open the refrigerator door (hot enough that the magnetic strip that...
Well, that is were a heating wire runs to evaporate condensation at the seal. So it is normal that it gets slightly hot, but if really hot, then call for service
Jun 18, 2017 | KitchenAid Superba® Architect® KSRP22FSMS...
My Subzero bar frig feels quite hot around the edge that touches the rubber and it is making the rubber warm as well. Everything inside is cold, and it is making ice as usual. I think I sense a smell of...
as with alot of refrig units the rubger strip has a warming coil that keeps the door from sticking they keep an even warm temp so as opening and closing the door easy there could be a burn spot in the strip and causing the strip tp be warmewr than it should be almost hot should call a fridge expert after you convince your other half there is a prob normally most fridges have a plan magnetic strip to seal the door
Aug 22, 2009 | Refrigerators
Kitchen Aid Fridge KSRF25FRBL00 - Hot Panel between doors
This strip is warmed to prevent condensation forming here during humid weather. Some models use a refrigerant pass of the compressor to warm this strip other use a heater that can be controlled by a 2 position switch in the refrigerator control panel that reads something like "Turn this on if moisture appears on cabinet exterior". If you have no such switch you should be aware that the strip is ALWAYS warm but barely noticeable until you develop a problem in the cooling system.
Check temperatures in the freezer (Zero Degrees approx.) and refrigerator (Approx. 30). If these are normal don't worry about the heat from that strip. If you find a temperature not normal you have the beginning of a cooling problem unrelated to that strip.
Aug 20, 2009 | KitchenAid Superba Architect KSCS25IN Side...
I have a 6 yr old Suberba. The center post between fridg & freezer is HOT and has been for several days. Any ideas?
That is normal and you may have just noticed that it gets warm or a little hot there. It is a heat strip placed behind the metal around your door to prevent moisture from forming around the door seal. If it was not there water would appear around the door on a daily basis, Thank You Sea Breeze
Aug 17, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Ice smells and tastes baaaad, water smells and tastes baad!!!! I changed the line and it still stinks...please help...
Check all of this;
  • Remove spoiled food
  • Clean refrigerator interior with a solution of hot water and baking soda
  • Clean the door seals
  • Remove breaker strips and check for wet insulation
To remove the breaker strips it is important to bring them up to room temperature first. If they are too cold they will be brittle and may crack. To warm the strips you can open the freezer and allow it to come up to room temperature (wait 2 to 4 hours) or you can soak a towel in warm water and hold it against the strips to warm them.
Good luck:
Don't forget to rate;
Jul 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
CENTER METAL SURFACE THAT DOOR SEALS TOUCH WILL BURN YOUR SKIN
go to partstore buy the part # DA97-01949A and fix it you can put the fan in back refrigerator keep it cool when the part come and fix it
May 11, 2009 | Samsung RS2630SH Side by Side Refrigerator
Cooling Fan is not working automatically
thass as good idea, but instead justreplacethe existing fan ( which is your problem)the fan is no good, so rewiring will not help any. replace the part!
Mar 18, 2009 | Whirlpool ED5VHGXM Side by Side...
Outside of refrigerator is hot - almost burning hot
The frame between the doors has a refrigerant line running through it to prevent moisture build up between doors (should be room temp. or slightly warm, not hot).
If that area between the doors is hot to the touch, you have two things to check: 1 - are the condenser coils under unit or in the back clean? 2 - is the condenser fan running in the back that is near the compressor running?
Aug 24, 2008 | KitchenAid KSCS25IN Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
185 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
