Question about Samsung LE26R73BDX 26 in. HD-Ready LCD Television
The volume control is stuck
Samsung LCD TV. Had this tv for about 3 months only and without any problems til now. Turned on tv this morning which gives a perfect picture but the volume is at zero and i can't move it up. Also the on-screen display for the volume is constantly on the screen. Turned the tv on again this afternoon but this time, the volume is at its maximum and i still cant turn it down. Please help. Chris
  • 1 more comment
  • eaglesclaw21 Oct 15, 2008
    Have a Vizio brand LCD TV. Having similar issues. The volume becomes stuck both up and down. Removing batteries from remote doesn't change the problem. When using the side volume controls it will either get stuck going to maximum or minimum. Buttons don't seem to be depressed but if they are is there a way to unstick them that doesn't involve steps that could potentially be more harm then good. I would rather not damage the TV by noobish mistakes.
    Regards
    Chris
  • Anonymous Oct 21, 2008
    I have the exact same problem volume first went to minimum but started working after a while, then two days later I turned it on and the volume went to max with volume display staying on as if button is being pressed...46"LCD Samsung.
  • jumpingj Jan 31, 2009
    I have a Samsung LCD TV LN40A650 that has the exact problem. I got a new HD comcast/motorola cable box and this did not solve the problem. I tried new batteries in the remote and still have the problem. I put the remotes in a box in case the volume down signal was coming from the remote - and stil no luck.
    Problem comes up within 10 minutes to a few hours of the tv being on.
    Suspect bad IR sensor - TV is going back to store.
  • 38 Answers
You didn't mention even using the remote. any way if it does not control even doing manualy or with remote control contact the dealer of you tv and discuss the problem. This could happen now a days LCD tv's has a program to operate. i suspended the program of your tv has reset.
Posted on Apr 20, 2008
How to remove Digital noise filter from my samsung lc450 lcd tv
hello, to remove that problem you can use this method;
1. Enter to menu - plug and play - than follow instructions 'til home use and store demo appear.
select home use. or,
2. Push volume button on side of tv until volume bar appear, than push menu button 3-5 second.
good luck.
Mar 27, 2011 | Samsung LE40R74BDX 40 in. LCD Television
My volume wont work
Sound IC problem. or main processor problem.
Check reloading the software. Refer to manufaturer
Mar 30, 2010 | Vizio VA26L 26 in. LCD HDTV
Samsung le40r74bd problem
I just had this problem with my 3 year old 32" Samsung LCD. The volume would go up and down by itself, normally just constantly going up even when it reached 100%.
I thought it might have something to do with the volume buttons on the TV itself so seeing as it was out of warranty anyway I decided to unplug it and open it up.
I gave it a good clean and I disconnected the cable for the panel of buttons on the LCD itself (volume, menu, channel etc) seeing as I never use them anyway. I then put everything else back together and tested.
It seems to be working fine now. Previously (for the past 3 hours) ever time I turned it on the volume level would come on instantly and stay on until I turned the TV off. So I’m quietly confident the problem has been fixed. But I must admit it’s only been 10 minutes, so who knows, it might come back.
Dec 18, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Frozen samsung TV - wont turn off
since you say you have had it just a short time
call samsung and request service for your set this is a problem and will get worse
if its just a couple months old parts are still in warranty and not sure of labor there is a warranty statment in the owners manuel
Nov 01, 2009 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
32 Inch Brand new Samsung 32" LCD showing subtitles / no volume??
I had a similar problem, checked all of the TV's control settings only to find out that my cable box had an independent "mute" function that automatically turned on the closed captions when activated. Once I found that and turned it off, all was fine.
Mar 18, 2009 | Samsung LN-R237W 23 in. LCD Television
Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Aug 24, 2008 | Samsung LN-S2651D 26 in. LCD Television
Samsung lns4041dx/xaa
Same problem with my set. The volume was either fully up, or fully down (usually down), and other controls didn't work- like I couldn't access the menus and could not adjust the width of the screen/aspect ratio.
Jun 03, 2008 | Samsung LN-S4041D 40 in. LCD HDTV
Sound problem
unplug it for a day. try again... the microprocessor is confused,
also check the button on the volume up and remote too make sure its not stuck down.
Dec 07, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung LE26R73BDX 26 in. HD-Ready LCD Television Logo
2,652 people viewed this question
Jerry Greenberg
Jerry Greenberg
