Question about GE JVM1850 1000 Watts Microwave Oven
Stuck in demo mode on GE jvm1850 microwave tried unplugging, tried power level and zero at same time, tried holding clear, holding help, tried everything i have read so far but they seem to all be for other models....
  • GE Master
  • 9,047 Answers
A hard reset would be the first thing I'd recommend, but unplug it for about 2 minutes, plug it back in, and watch to see what it does.
Wait at least 60 seconds after powering it up to see if an "F3" code comes up.
You can download GE owner's manuals and installation instructions here. See what it says about a demo mode.
Otherwise, I would suspect a shorting keypad.
If you need more help, we can let you know what your options and costs would be and send you other helpful info.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 06, 2010
How do I turn off demo mode?
I had a hard time to find this fix. you unplug it for 1min and then plug it back in and press and hold the power and 0 keys for 30sec. That is it
http://forum.appliancepartspros.com/microwave-repair/33654-stuck-demo-mode-no-heat.html#ixzz48TqseDoE
Jan 18, 2016 | GE XL1800 1100 Watts Microwave Oven
Microwave lights up, turntable turns and fans run however food does not heat up. I have checked to ensure the power level is up which it is. Tried the express 1 minute as well as using the time mode and...
The problem is one of three things, the magnetron "common issue" the high voltage capacitor and diode can be a factor, all three work together in conjunction with the high voltage transformer to generate the high voltage that heats the food.
Mar 05, 2011 | GE JVM1850 1000 Watts Microwave Oven
Stuck in demo mode after power outage - any ideas on how to get it out? model is JVM2070
Talked to GE Help Line (1-800-626-2005) and found out the magic key combination for this microwave. Plug in after being unplugged for at least 30 sec. and then press Help plus Boost at same time for 3-4 seconds (until it beeps). The microwave will now be in normal mode (I assume you do this to put it in demo mode as well).
Sep 13, 2009 | GE Profile Spacemaker Over-the-Range...
GE Microwave DEMO MODE
The owner's manual (which can be downloaded here) doesn't show any demo mode, but it may exist.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Oct 06, 2008 | GE JE1590 Convection / Microwave Oven
Demo mode
I had the same problem trying to get rid of demo mode. Press the "clock" button 3 times in a row and problem fixed!
Jun 19, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
Demo Mode
Unplug the microwave for at least 3 minutes, then plug it back in, and BEFORE SETTING THE CLOCK, press and hold power level and start for three seconds. This should flash "demo mode off". Set the clock as normal. Enjoy!
Mar 31, 2008 | GE Advantium SCA2000B Microwave Oven
DEMO MODE
how do i change the bulb inside the microwave ge xl 1800
Feb 13, 2008 | GE XL1800 1100 Watts Microwave Oven
I just bought a condo with a GE Spacemaker Mod# JVM1860SD
that was stuck in demo mode. (This mod# has been replaced by the JVM1870*** series)
I called GE twice in two days, and finally got someone who had the solution (and it worked):
  1. Unplug the unit for at least 30 seconds
  2. Plug the unit back in DO NOT SET THE CLOCK
  3. While the unit is still "booting up" and the display screen is lit with gibberish, HOLD THE POWER LEVEL AND THE ZERO BUTTON for at least 5 seconds.
  4. After 5 seconds, the screen will display "demo mode off"
It messed me up at first because the power level and zero pads don't beep when the unit is booting up... but it worked.
- Again, this is for the GE Spacemaker 1860-1870 series models only - The women who gave me instructions said she had different demo mode unlock methods for the 1400, 3670, 2070 etc... so call GE if you have a different model.
P.S. my model looks like this - the keypad setup is key http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SPECPAGE&SKU=JVM1870SK&SITEID=GEA
Mar 01, 2007 | GE Advantium SCA2000B Microwave Oven
GE JVM1850 1000 Watts Microwave Oven Logo
136 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
