Question about Whirlpool GU2700XTSS / GU2700XTSY Built-in Dishwasher
The dishwasher makes a whining noise while washing; It started doing this a short time age. The dishwasher is about 1 1/2 years old. It almost sounds like there is something in the pump, , but I can't find a schematic.
    President:
  • 949 Answers
The problem would be either something in sump area of the pump near the chopper or a bad main bearing in the motor. Since it is fairly new I would suspect something in the sump. I have put together some instructions on how to take this apart and clean. Let me know if this helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Posted on May 05, 2010
Dish water is not working. Water fills but no noice after that.
it's obviously sounds like your pump has gone, but considering the age of the machine, it would probably be best to get a new machine, that way you would have a 5 year warranty with it aswell so it's win/win really!
Jan 05, 2013 | Dishwashers
GE pdw9980lss dishwasher makes a horrible squealing noise when not in use.
The dishwasher control panel must be defective, nothing else would cause this.
Apr 04, 2017 | GE 24 in. PDW9980LSS Stainless Steel...
Dishwasher makes a whinning noise during the washing cycle. I have opened to check inside, and the dishwasher is ok for a few minutes, then it starts whinning again. The dishwasher is just over a year old,...
If wash quality is OK leave it. Pump will make whining noise due to its' ball/bush bearing problem.
Some times if the water inlet flow is not free in flow also results in noise.
Clean the inlet water filter and check the flow before re- connecting to the machine.
Aug 30, 2010 | Dishwashers
Our kitchen aid dishwasher is about 7 years old, recently it has begun making a high pitched whine while the wash cycle is running. The dishes are still clean, but the noise is new and annoying not to...
Sounds like it could be the bearing in the wash motor. If the sound is only present when you can hear water being thrown around then this would confirm it. Not sure about spares availability on a 7yr old machine though
Jan 18, 2018 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher will not go into wash cycle.
On the LG LDF6810 dishwasher, the best you can do is remove the bottom spray arm and then the 10 phillips screws that hold the filter down.
Pull the filter out and clean it as best you can.
Inspect the sump area beneath where the filter was. Be careful of broken glass and remove all debris. Use a flashlight and look into every little spot down there. Reassemble the dishwasher and operate your DW.
If you still have problems, I recommend a service call. Check your manual to confirm but most LG dishwashers have a 1 year parts & labor plus a 2 year parts only. Have your proof of purchase ready.
Apr 02, 2009 | LG LDF6810ST Stainless Steel Built-in...
Whirlpool Dishwasher Model: GU2500XTPQ3 making loud whining noise
It's most likely coming from the wash motor bearings. Based upon the age of the dishwasher it might be time for a new one. Although it can be fixed by replacing the motor. It's usually easiest to change the entire sump assembly with the motor. You will have a new wash system. Part number W10782773 Dishwasher Pump Motor Part Number 8535150 Sears PartsDirect
Feb 22, 2018 | Dishwashers
How do you fix a noisy whirlpool dish washer DU1100XTP(Q) ?
A hard object has entered the wash module (on some models).
When the object is ground up, the sound should stop. If the
noise persists after a complete cycle, call for service.
Mar 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kenmore automatic dishwasher
Sounds like a Bad Solenoid. Locate the part then tap it with the back of the Screw Driver during the cycle. see what happens.
good luck
Kashif.A
Mar 06, 2008 | Dishwashers
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Got much noisier over time
Hello Hunting2000 the noise could be several things. If you heard what is water hitting against the inner door, try aranging the dishes so that the water is hitting the dishes and not the door. I assume however this isn't the noise you are talking about. Sometimes over time the wash arms themselves will start to make noise. This is from wear. Yes less than a year sounds like a short time. This could have been there from the start. I would call Bosch Customer Support and see if they will pay for a 2nd opion. This well could be the wash arms causing this. Espically the top one not sealing proper and allowing water to hit the front. Hope this helps.
Jan 28, 2008 | Bosch 24 in. SHE44C05UC Stainless Steel...
Open Questions:
See all Whirlpool GU2700XTSS / GU2700XTSY Built-in Questions
Whirlpool GU2700XTSS / GU2700XTSY Built-in Dishwasher Logo
232 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
