The car starts fine (my daughter's car with 103,000 miles) - intermittantly can't press the button down to put it in gear. After she shuts it off a few times and restarts the button will press. It shifts fine once in gear.
CHECK MAKE SURE BATTERY FULLY CHARGED IT HAS TO BE 12.5 VOLTS BEFORE THE BRAKE TRANSMISSION SHIFT INTERLOCK SOLENOID WORKS.IF BATTERY POWER GOOD CHECK BRAKE LIGHTS TO SEE IF BRAKE LIGHTS SWITCH IS WORKING.IF NO CHECK FUSE.IF FUSE GOOD BRAKE LIGHT SWITCH IS FAULTY. IT CONTROL THE BRAKE TRANSMISSION SHIFT SOLENOID ALSO THE NEUTRAL SAFETY SWITCH.IF FUSE AND BRAKE LIGHT SWITCH IS GOOD.YOUR PROBLEM COULD BE A FAULTY NEUTRAL SAFETY SWITCH OR BRAKE TRANSMISSION SHIFT SOLENOID FAULTY.
