Question about Amcor 3900 GPS Receiver
I broke my holder for mounting on a car window. Can I order another one?
  • 776 Answers
The holder csn be purchased online at couple of online portals.
The link to purchase are enclosed below:
http://www.gomadic.com/amcor-3900-car-bean-bag-holder.html
http://www.amazon.com/dp/B0026RMU8U/?tag=nzbestbook-20
Posted on May 05, 2010
My Klipsch cs 500 has no sound. Blue light is on and I have tried every combination on remote to no avail. Any ideas?
There is the panel mounted 4amp fuse, and then there is a circuit mounted 6amp inline fuse as well. Mine blew due to a power surge that blew up other things in my house as well. It’s a bear to get the circuit board screws off, and some green sealant off! Step 1) I’m ordering a panel mounted fuse holder that is the same style as the 4amp fuse holder. Step 2) drill hole in panel, and install fuse holder Step 3) no need to remove old fuse (since its blown) so I’m soldering wires from new fuse holder to the fuse ends on the circuit board
Oct 29, 2017 | Klipsch Audio Players & Recorders
Moen eva tissue holder broke, how do we fix it?
Specifications and Installation Instructions:
http://www.moen.com/shared/pdf/yb2808sp.pdf
Identify the parts needed and the part number from above.
To order replacement parts:
http://www.moen.com/replacement-parts/search?context=modelNumber&value=YB2808CH
If your tissue holder has simply come loose it is likely the the wall mount will need to be replaced or at the very least tightened. You will need to remove the tissue holder from the mounting bracket. Insert a small flat screw driver in the square hold at the underside of the base of the mounting post to release the locking tab. Try to tighten the screw holding the mounting braket; if it will not tighten you may need to replace the wall anchor. Once the wall anchor is replaced you can reinstall.
Apr 02, 2011 | Home
I have a franklin towel bar and the mounting bracket broke at the screw hole. is there replacement mounting brackets avaible?
Probably not, but if they sell a toilet paper holder of the same style the bracket might be identical to the towel holder, but would be cheaper than buying a new towel bar. Good luck, Al K
Mar 16, 2011 | Franklin BATH UNLIMITED NORTHPORT TOWEL...
How do i change a brake light bulb on 2000 vw jetta?
Removing:
  • Switch off all electrical consumers, switch off ignition key and remove ignition key.
  • Remove rear luggage compartment side panel trim (left or right).
  • Remove 3 nuts, arrows, and remove housing.
  • Remove bulb holder.
Installing:
  • Install bulb holder.
  • Insert housing into body opening.
  • Tighten nuts.
  • Install applicable rear luggage compartment side panel trim.
Rear Light Bulb Holder Removing And Installing:
Removing:
  • Disconnect electrical connector.
  • Depress retainers, arrows, and remove bulb holder.
98971817.gif Installing:
  • Install in reverse order of removal.
And the Center Mounted Brake Lamp.
High mount Brake Light Removing And Installing:
The high mount brake light is installed in the rear shelf.
98971288.gif Removing:
  • Disconnect electrical connector from high mount brake light.
  • Remove rear shelf
  • Un-clip high-mount brake light from rear shelf, arrows.
NOTE: The bulb holder base plate contains soldered- in light emitting diodes (LEDs) that are not replaceable. In the event of LED malfunction, replace complete bulb holder.
Additional
Mar 13, 2010 | 2000 Volkswagen Beetle
Canon 7200 Staple Holder
You can order the part through Canon or get the part number from their service department and try ordering it 3rd party. Check your user's manual for a service toll-free contact number.
Aug 28, 2009 | Canon imageRUNNER 7200 Copier
The man computer will not record sensor or catalytic activity, Reads "not ready".Want to replace computer, where is it? under dash in side kick panels?
1 Remove the cover of the main fuse box on the side of the dashboard. 2 Remove the knee shield above the pedal assembly. 3 Lift out the air duct to facilitate access to the relay holder behind it. 4 Remove the screw securing the relay holder and press the holder down.
The Integrated Central Electronics (ICE) module is mounted above the relay holder. 5 Install in reverse order.
Aug 18, 2009 | 1996 Saab 900
How do I install a new cartridge holder?
Click this link for a service manual free download for your multipass c2500 inkjet printer troubleshooting.
This will help you replace the holder.
If you cannot click just copy and paste the following link into your browser window.
http://www.nodevice.com/search.html
Apr 30, 2008 | Canon MultiPASS C2500 InkJet Printer
Windscreen holder for tomtom
I didn't like the suction mount because it doesn't always hold very well and it was a little distracting. I found a vent mount at mountguys.com for less than $15 delivered that I am very happy with.
Jan 27, 2008 | Tomtom ONE GPS Receiver
Amcor 3900 GPS Receiver Logo
35 people viewed this question
Top Amcor GPS Experts
Will Halftowaite
Martin Murray
Are you an Amcor GPS Expert? Answer questions, earn points and help others
