Question about Acer Aspire One PC Notebook
How can I access my old Mac harddrive (now in an external shell) on my netbook(PC)?
    President:
  • 1,851 Answers
There is a kit sold around - I have one it works well that you power up and USB to the PC - laptop and otherwise. You will need to either configure the external shell which should USB to the current Netbook. or just use this CLICK HERE unit from Tiger Direct.
Posted on May 05, 2010
Unable to read external HDD after plugging it to a Mac (previously it is readable via a Windows PC)
Chances are it was formatted as NTFS format by the PC which is not MAC compatible. You will need to reformat the drive in HFS format if you want it to work as a MAC disk only or in FAT32 format if you want to read it in PC and MAC machines.
Jul 24, 2014 | Western Digital WDG1C2500N MyBook Premium...
My acer chromebook AC710 SCREEN IS CRAZY CANT SEE ANYTHING BUT COLORS AN LINES WHAT TO DO?
The reason your monitor is in screensaver mode, (Read your other problem too), is there is no video signal coming to it.
No Signal
This is because the Netbook isn't sending one.
It isn't sending one because apparently you have graphics problems. Problems with graphics hardware.
So no, there is no Sync, or settings to change on the monitor.
(It is Not a video/graphics card. Your laptop uses Integrated Graphics. Intel HD 3000 Graphics )
However the point is moot now. Netbook is being sent in.
Point now is getting the info off the Harddrive, before some geek looses it.
(I'm a computer geek too, so that was no slam)
Remove the Harddrive. Then install it in an external enclosure.
You've seen an external enclosure, if you have seen an external harddrive.
You can buy just that 'outside case', too.
The external enclosure has a USB cable going to it.
The USB cable goes inside the enclosure, and connects to a small circuit board, with an interface on it.
The harddrive plugs into the interface.
The external enclosure comes apart VERY easily. Manufacturers make it easy to open the external enclosure, and install the Harddrive.
Usually a 2 piece case. One screw to open. Remove cover, plug Harddrive in, replace cover.
Plug USB cable into a USB port, on a working computer.
This is one example that will work with your Harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
[Harddrives are measured across their width.
A laptop harddrive is 2.5 inches across in Width. 2-1/2 inches.
A desktop harddrive is 3.5 inches across in Width.
Three technology styles of Harddrive, are presently being used;
1) IDE (PATA),
http://en.wikipedia.org/wiki/Parallel_ATA
2) SATA,
http://en.wikipedia.org/wiki/Serial_ATA
These two types of Harddrives use mechanical parts. For example a Spindle, Spindle Motor, and Platters,
http://computer.howstuffworks.com/hard-disk.htm
3) SSD,
http://en.wikipedia.org/wiki/SSD
No mechanical parts. Just electronic components. (Solid State)
Your laptop uses a 2.5 SATA harddrive ]
Going on..................
I haven't had any direct dealings with this laptop. Or the Aspire V5-171 version.
I see no Service Manual listed.
Searching the internet for Harddrive replacement info though, I ran into that there is a large panel on the Bottom of the Netbook; which has a single Philips head screw in the middle.
Remove the screw, remove the large panel.
This is supposed to be in the User's Guide, but cannot seem to download it right now to see.
It will be in replace the Memory. Ram Memory.
The Harddrive should sit in a compartment area all it's own.
The Harddrive itself will be in a sheet metal Caddy. Harddrive Caddy.
Remove a screw, or screws; to remove Harddrive, and Harddrive Caddy.
Once screw/s are removed, L@@K at the Harddrive.
There should be a piece of 'silk strap', to pull on.
Keeping Harddrive flat, and down in Netbook, pull on the strap; and pull the Harddrive across towards the OUTSIDE of the Netbook.
You are unplugging it.
You DO NOT want to lift straight up on the strap, as you will bend contact pins.
Once the Harddrive is slid over, then lift at an angle; and remove.
Lift up on the Back of the Harddrive.
This is the opposite side of the one that plugs in.
Open the external enclosure case, slide the harddrive in; then close the external enclosure case. (Referring to Tigerdirect example. Other external enclosures will be different)
Plug the USB cable into any working computer's open USB port.
Look in My Computer/Computer. (WinXP/WinVista - Win 7)
The external harddrive will be shown.
DOUBLE-click on the drive letter it is next to.
Have problems with that post back in a Comment.
Your Netbook, is supposed to be just an ACER Aspire V5-171 series of Notebook PC; with a Chrome logo on it.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 05, 2013 | Acer Computers & Internet
Which mass storage device asus eee1005ha is?
The harddrive
(A USB thumbdrive is a removable mass storage device.
An external harddrive is a removable mass storage device.
A harddrive is a mass storage device that is installed IN the netbook.
NOT considered removable, therefor the one mass storage device)
Regards,
joecoolvette
Dec 17, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
How do I back up a defective hardrive on a Netbook with no optical drive?
There only is one way. Take the harddrive out of the computer and connect it to a working computer. It will then serve as an external harddrive where the operating system does not work but the contents are in tact so you can back it up that way.
Thank you for visiting FixYa!
May 26, 2011 | Mirus (00398577000P) Netbook
I turn on my sysnet582 sylvania netbook and get operating system not found
Go to the DigitalGadgets.com website and download the "OS update" (probably not the OS Shell update) follow the directions as listed. You will need a 1-2 Gigabyte SD card.
This will re-install the OS. Please note you will lose all data that is not on external storage.
You can try the OS Shell update. If you are not happy with that you can locate a copy of the previous OS update through the Yahoo Sylvania Netbook group.
May 23, 2011 | Sylvania G-Netbook
My acer netbook 532h will not power on. just before problem the power on button stayed on and nothing happened; battery was pulled to turn unit off. unit has a blue light under the light bulb icon turn...
Two things to try first before we go further with the diagnosis:
1. Try to power up the netbook with the external hard drive disconnected & see if it will work.
2. Try powering up the netbook from the AC adapter only with the battery removed.
Nov 28, 2010 | Acer Computers & Internet
Hi i have a smartdisk crossfire external harddrive which I have used to save my photos from a windows based pc. However I have now purchased a IMac and wish to be able to load my photos on to this. When I...
congratulations on switching to mac!plug the external hard drive back into the PC, and copy the photo's to the PC, now plug it into your mac and go to applications-utilities-disc utility, the external drive should be listed on the left,click on the erase tab, at the volume format select "ms-dos file system", then click the erase button, this will erase everything on the drive and set it up so your mac can use it (but its ok because you moved all your pictures to the PC) now you can go back to the PC and copy the pictures on the external drive and it will work with your mac.
Jul 04, 2010 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
Harddrive is not recognisable by both PC and MAC.. Its either one or the other..
Partition the drive into 2 250 Gig partions, Call 1 partition MAC and the other one name PC, for the apropriate partion on each machine
Apr 13, 2009 | Computers & Internet
Installing old drive into new drive
If the problem is in the controller inside the case which in 99 percent of the times it is, This will certainly fix your problem. The MTBF(mean time between failure) of harddrives is 100,000 hours of operation. Also, any external case can be used that matches your hard drives specs...size, IDE, SATA ect...
Hope this helps you,
George
Jun 22, 2008 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
I/O Device Error on External Hard Drive
try doing a disk check on it
1 hold down the windows key and press r
2 type in cmd
3 in the shell window type in chkdsk /F /X e:
Replace the E: with your harddrive letter
May 04, 2008 | Computers & Internet
Acer Aspire One  PC Notebook Logo
14 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
