Question about Sony Handycam DCR-TRV33 Mini DV Digital Camcorder
Stuck in nightshot
Even with the switch in the off position, nightshot is still active.
    Novelist:
  • 145 Answers
The problem may be with a defective switch on the inside or simply that the switch wore out or the inner lever broke. If the switch does not have a solid click feel but a smooth glide then the internal lever broke, if you cannot feel a difference then the contacts either came off the board or they are worn/dirty. You can press down lightly and then move the switch. You can also try cleaning the internal contact by removing all power sources "charger and batteries " from the device and dropping a small amount of rubbing alcohol in the switch where it can slowly flow into the inside a little and then rock the switch back and forth 10-15 times and then let dry for an hour or too. This should help some.
Posted on May 05, 2010
Horn sticks in the on position and keeps honking. what is the cause
Sticking contacts in the horn pad switch, bad clockspring and even a bad horn relay that is stuck or burned.
Jun 17, 2015 | 1998 Jeep Cherokee
Sony HC5 stuck in nightshot
This is most likely a broken or misaligned switch on the internal lens assembly and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Jan 18, 2011 | Sony Handycam HDR-HC5 Camcorder
Can't turn off nightshot on my handycam help!!!
Option 1:
Using the NightShot:
1. First Set the POWER Switch to Camera, Slide NIGHTSHOT to ON.
2. The NIGHTSHOT indicators flash on the screen.
3. To cancel the NightShot mode, Slide NIGHTSHOT to OFF.
Option 2:
1. Let us try to reset the Camcorder and check if it helps to resolve the issue.
2. Locate the RESET button behind the LCD screen of the Camcorder.
3. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object.
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
Good Luck!!!!!!!!!!!!!!!!!!
Sep 13, 2009 | Sony Handycam DCR-TRV16E Mini DV Digital...
Nightshot
switch to MANUAL mode, then in SHOOTING MODE select NIGHT or TWILIGHT
Jun 15, 2009 | JVC Everio GZ-MG360 HDD Camcorder
Ccdtrv608 sony handycam stuck in nightshot mode
Below image of CCD-TRV608 shows NightShot Button location, turn it Off for normal mode recording.
Mar 24, 2009 | Sony Handycam CCD-TRV68 Camcorder
Can not set the camcorder to Super Nightshot Plus mode
To enable " Super Night Shot " option, find slide switch at top of camera as shown in picture...Regards,
Aug 21, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Cant clear nightshot plus mode
Night Shot option can be OFF by switch at top of camera.
Jul 25, 2008 | Sony Hi8 CCD-TRV138 Camcorder
How do you turn "Nighshot Plus" off
it should be right on the top of the camera. the big switch. its not in any of the touch screen menus
Feb 25, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
DSC-F717 - "stucked" in nightshot mode
Yes you are right, it is more than likely the nightshot button that has shorted.
This is button is part of what we call the Switch control Block.
Phone your local Sony service Centre and ask them how much it would cost to replace the switch control block. My estimate is about a 1/5 of the original cast you paid for the camera.
Good luck.
Sep 24, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Nightshot Plus
If you really feel up to it the thing has screws, start opening them and take of the plastic cover. But think 4 times before messing with a 400 $ camera, maybe you'd rather take it to a lab, shouldn't be too expensive. There's many things that can go wrong if you do it yourself Good luck
May 14, 2006 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony Handycam DCR-TRV33 Mini DV Digital Camcorder Logo
216 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
