Question about Sterling Plumbing 1500D-31S VISTA PIVOT SHOWER DOOR
I put the door in with it opening in the wrong direction. How can I switch it?
  • 2,926 Answers
Through my experience with the exact same issue, I found that my only alternative was to remove and replace the door and jams in the right direction. The hinges, door knob hole and catch will have to be reversed and with he existing holes and mortise joints already cut on the door and jam, the best solution is to correct it. Regardless of what is done, you'll spend more time correcting and hiding the pre-existing cut outs. It is much faster and easier to correct it, than to modify it. Just thought I'd pass along what I have experienced.
Posted on May 05, 2010
The doors open in the wrong direction
remove top screw for freezer door remove door then remove next hinge then remove fridge door reverse hinges when putting back on reverse handles to other side
Mar 01, 2014 | Thetford NORCOLD N641R - Norcold Finished...
Light not working
Replace the light switch at the top of the door opening. Kill the power to the unit, pull down the grille up top, then remove the cover over the switches. the light switch is the one with the white back. The one with a black back is the fan switch. pull the 2 leads off, open the fridge door, squeeze the switch with a pair of pliers to pop it out of the opening, then install the new switch in the opening facing the same direction. put the wires back on , in any order doesn't matter, put the cover back on the switches, then the grille back on and restore power to the unit.
Nov 10, 2013 | Sub-Zero 611 / O Bottom Freezer...
Door jamb switch
all doors there are drivers, and then OTHERS, (wiring)
its wired OR logic, so any switch grounds, it turns them on.
and is programmable on all cars. to have this on or off (features explained in the operators guide, lost that?)
CRV has 3 lamps
front dome
rear dome
and spots.
all of them are messed up? for all doors.
if yes, ITS programming. is wrong.
the rear light is directly controlled lamp to rear lamp. (hatch glass or gate switches.
and has a slide switch, off,on, auto.
the spots lamps are direct. on, or off
the front however is totally different and wired unique.
as you know the drivers door is unique, as it operates the
keys left in igntion, or head lights left on, mode. so if those work
right then the drivers door switch, is,, working......
the front dome
has 3 modes. again , off , on and auto .
Auto is the MCU , unit, the MCU sees any door open and the front dome gets input to the AUTO pin, and if in auto the lamp glows.
i dont think the MCU is programmable but do read the oper guide for that., i dont have one.
Jul 30, 2013 | 2006 Honda CR-V LX
Door light stays on i sprayed wd40 on the sensors not helping
then you need to pull them out and replace them. there is not really much to go wrong. when the door is open they release and put a ground on the bulb. if you light is on, then you have the interior
3 way light switch in the wrong position, or the door switches are broken
Jan 18, 2011 | 1990 Toyota Celica
'89 door lock
you either have the wrong ones or there installed wrong actuators don't work in one direction repair manual are not going to teach you how to do something they give a insight of how some thing is done
Aug 15, 2009 | 1995 Ford Mustang
I have a 2001 Lincoln LS. My rear passenger door
you can try feeding the switch direct but you will need to find out which wire carries the power to the switch,this can be accomplished using a test light or small meter. when you find which wire carries the power to the switch then you by-pass the switch and put the power to the other side of the switch manually instead of using the switch and the door lock will undue ut self. then you can change the door lock actuator.
Jul 30, 2009 | 2000 Lincoln LS
1993 Lexus LS
To put the windows up manually you will need to get inside the door. It sounds like you could have a bad switch. If you take the door off or can take out the window switch panel, put a jumper wire on the switch that tell the window to go up. If this is not working go directly to the motor where you can give the motor power by closing the circuit at the motor and the window will either go up or down. If it goes in the wrong direction just reverse the polarity of the wires.
Oct 30, 2008 | Lexus LS 400 Cars & Trucks
Sterling Plumbing 1500D-31S VISTA PIVOT SHOWER DOOR Logo
44 people viewed this question
Top Sterling Plumbing Home Experts
john h
Mike
Are you a Sterling Plumbing Home Expert? Answer questions, earn points and help others
