Question about Frigidaire Dishwashers
Calcium bildup calcium buildup appearing on glasses & silverware, also on heating element
    President:
  • 949 Answers
I created a tip sheet to help with this, let me know if you have questions beyond what is in this link.
http://www.fixya.com/support/r4666624-hard_water_calcium_white_powder_build_up
Posted on May 05, 2010
DU940gwdg3 dishwasher does not wash well. Top, bottom and silverware come out dirty
Is the heating water element getting hot? Is the filter screen in the bottom of the basin clear of food debris? Do you pre-rinse the items being washed?
Apr 21, 2017 | Dishwashers
Clear glasses and silverware have film and some particulates. Silverware is on bottom and glasses on top. It's a KUDS03FTSS3. Have had the filter area cleaned. Have used vinegar. Have used less soap,...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
Nov 12, 2010 | KitchenAid Dishwashers
My dishes and silverware have a dry film on them, possibly water deposits. The food is off but the glasses and silverware look bad and don't look clean with this residue on them. Washer is 9 years old
Check your heating element..
A bad heating element causes many problems in dishwashers…
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | Whirlpool Dishwashers
I have just moved into a home with a 1 year old Whirlpool Gold GU2400XTP Quiet Partner III. THE DISHES ARE NOT CLEAN, GLASSES HAVE WHITE SPOTS, SILVERWARE AND PLASTICWARE HAVE WHITE FILM. I am using...
heatman101
Sep 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I have a GE Eterna Series Triton XL. It is not cleaning the dishes very well. The top dishes (glasses & mugs have debris in them. Silverware not very clean either. Can you help. I have checked the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 01, 2010 | GE Dishwashers
Calcium buildup on heating element. It's unmovable.
The reason for the calcium build up is normally a hard water,Make sure the salt dispenser is full (located at the bottom of the machine under the lower rack,before you add salt get a descaller from you local hardware store, most carry for dishwashers.Follow instructions, this may require a few treatments before it is gone,when it is right then check salt level etc.Hope you come right.
Dec 30, 2009 | Dishwashers
At some point the dishwasher leaks onto the floor. what could be the possible problem?
this are the possibilities for the leak :-----
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was used...dish sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket.
Sep 23, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Heavy calcium buildup on the heating element
Get some c.l.r. (calcium,lime,rust) remover at a supermarket.Add a cup and run a cycle,this should solve your problem--repeat if necessary.
Nov 13, 2008 | Dishwashers
Dishwashers Logo
64 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
