Konica 1112 Error code 35
How do I clear the error error code 35
  • Wee Bobby Mar 27, 2008
    Thanks Nitrotrike,
    The error code 35 was caused by a fluke. I inserted paper into the manual feed tray before the copier was up to proper temperature.
    I did take it into the dealer for repair. He just cleared the error code and it seems to be ok now. I was just wanting to know the proceedure for clearing the error code in case it happens again.
    Knowing the proceedure could possibly save me two 1hr trips to the dealer.
    Thanks
  • brian c
    brian c May 11, 2010
    Code 35 is a fuser overheat / underheat condition error.
    Unless a repair was made, the code will return when the machine sees the fault again.
  • 589 Answers
The procedure is as follows:
1. Turn machine off.
2. Turn machine on while holding the 2 & 5 keys.
3. Enter 47 on the keypad.
4. Press the Stop/Clear.
5. Enter 0 on the keypad.
5. Press the START PRINT button.
Power the machine off and on to exit the service mode.
You're done!
Posted on Mar 27, 2008
Error code 35
error code 35?
error codes on the minolta print /copy machines usually have a letter followed by four digits e.g. C2035,
please indicate which model and exact error code with a description of the error as seen by the user.
Sep 25, 2013 | Konica Minolta Office Equipment & Supplies
I just ask my copier to try to enlarge past 200%, had really little type on the original. It says "call service" code F-35-1. I work from home and need help to clear out this message. Please...
Fuser error, here is the reset procedure.
Set SW2 (sub power switch) OFF and then back ON, after set to "0" the bit 1 in DIP SW3 in 25 mode. (If you switch power back on without releasing the latch, the error will recur.).
Hope helps.
Sep 02, 2011 | Konica Minolta Office Equipment & Supplies
KONICA 7020 GIVES ERROR MESSAGE F-35-1O WHAT IS WRONG
hi
error f 35 is fixing error,try to reset on 25 mode
Jan 08, 2009 | Toshiba E-Studio 3511 Color Copier
Error code
Problem: The Digital Panel is Reporting Code 34-1, 34-2, 35-1, 35-2 or 36-2 Cause: The copier is having a problem with the fusing unit.
Solution:
  1. This is occasionally a false alarm. Try turning the copier off for about 10 seconds and turning it back on. If the code doesn’t clear, please call 1-800-877-2679 for service.
Sep 02, 2008 | Office Equipment & Supplies
Error code f35
konica f 35 eror code
Aug 06, 2008 | Office Equipment & Supplies
Error code f-35-8
On most Konica copiers, an F35 error indicates:
1. low temperature of the fuser; and/or
2. open lamp; or
3. open thermo wire fuse; or
4. open thermistor; or
5. or anything heat related at start or warm up.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 19, 2008 | Office Equipment & Supplies
Konica 1112 service manual
I have a konica 1112 copier all of a sudden it gives me a black page no codes to read someone told me it is the cleaning blade is this hard to replace
May 14, 2008 | Office Equipment & Supplies
Konica photocopier
My service info doesn't go back that far either, but this procedure should work to reset the code. However, I would make sure there's no toner build-up on the fuser thermistor or thermostat first, otherwise the code will reappear.
Here's the instructions on clearing the code:
Enter the 25 mode by holding down the 2 and 5 keys while turning on the copier.
Press the P key, then enter 47, then press P again.
Enter 0 and press the Print key.
Turn the machine off/on to exit the 25 mode.
If the code reappears, then theres a problem. If it doesn't, you're good to go!
Nov 11, 2007 | Konica Minolta DiALTA CF910 Copier
Error F-35-4
problem konica F-35-4
Oct 15, 2007 | Office Equipment & Supplies
439 people viewed this question
k24674
jasbo
jasbo
