How about disconnecting your pond lite, and then trying your dryer? Usually pond lights are wired with some sort of ground fault protection. And this will trip immediately if there's another source...especially a heating source with a motor. Its the motor that senses the gfi, and trips it. I'd disconnect the pond light from the dryer, and then try it. If it works fine, then get another power source (not linked to the dryer) to run the pond light and see how it works. I believe when you separate their power sources, you should be fine. Try this, and then let me know if you have success, or need some more guidance. But I'm most sure this is it. Good Luck, and I hope this works for you. - Jim
