Question about Jensen VM9410 Car DVD Player
How to bypass the ebreak with the vm9313 model? Is there any codes or anything?
  • 566 Answers
Hi megan
Although i have some reservation,i`ll assume your car does`nt have the parking brake wire so here`s the answer to your question;
You do not need to connect that wire but you need to bypass the parking brake function in the menu.
Here`s the parking brake bypass procedure:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number
entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Warning; use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
Hope this help Cheers
Posted on May 05, 2010
  • Jacques Marin
    Jacques Marin May 05, 2010
    By the way;
    That procedure is for the model vm9312
    But it should work with yours.
Has anyone used this method for the vm9313 model
Posted on Jun 07, 2010
  • amortega272 Jun 07, 2010
    has anyone had success using this method for the vm9313 model
How do I bypass the brown and white wire to have my dash lites and break lites working?
Your year--make--model didn't post for some reason? That info would be helpful.
I can't look anything up w/o more info? I need to look at wiring diagrams. Usually, bypassing anything, is not a good idea.
My US automotive database only covers vehicles sold in the US.
Jan 14, 2016 | Cars & Trucks
Bypassed the ac with shorter belt, but engine light is on and the car will not stay running
Year/make/model???? Some vehicles are not designed to bypass the AC. Are all the pullyes turning in the same direction as they were prior to bypassing? If the AC is designed to be bypassed,doing so should have no effect on the check engine light or stalling. Check the codes to see what area may be giving you the problem. ANything you may have disconnected while doing this repair that may be loose or not plugged back in??
Oct 18, 2015 | AC Cars & Trucks
Elantra won't start and moves when it's in park
I'm going to say something happened to the cable between the shifter and the transmission. There is a switch on the transmission that prevents you from starting the engine in anything other than park or neutral. The transmission is probably in reverse or drive which would allow it to roll.
Someone would need to check the lever on the trans where the shift cable is attached.
Sep 17, 2012 | 2006 Hyundai Elantra
My 99 s10 has no check engine light even when just turning the key, won't start and the fuel pump wont turn on. Changed ECM, Body control module, and ignition switch. I have checked all Fuses and...
IF FUEL PUMP RELAY IS NOT WORKING THE COMPUTER IS NOT READDING IT THEIR IS NO BYPASSING THE COMPUTER(ie) DOT CODE on that model vehical THE MASS AIR SENSOR REGULATES 90% OF HOW THE IGNITION TIMING RUNS I USED TO GET AWAY WITH IT ON OLDER MODELS NOT ANY MORE!?
Aug 30, 2011 | Chevrolet S 10 Cars & Trucks
Ebreak on the floor not releasing the break on excalade 2005
The cables and sometimes the hardware for the e brake corrodes and will stick when pushed. With an automatic trans the E brake does not get used often and sticks when you try.
Jan 04, 2011 | Cadillac Escalade EXT Cars & Trucks
How do i bypass the e brake on xdvdn9131
you need Z7 module to bypass this no more codes for this go to www.x-pert-s.com for more answers on this 5a7345d.png
Mar 04, 2010 | Dual XDVD8182 Car DVD Player
Dual xdvd 8625 double din emergency brake bypass
you can ground it,then enter the code 26604 after u insert a dvd real dvd then press stop twice then enter the code it should work
Jun 06, 2009 | Dual XDVD8170 Car DVD Player
Jensen VM9410 Car DVD Player Logo
377 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
