Question about HP Compaq 6720s PC Notebook
Hp compaq 6720s says pxe - e61
Hp compaq 6720s says pxe - e61 problems with laptop loading programs and dongle, so opted to install windows xp......wotever happened and have now run disc sanitizer and cleared hard drive but can´t access the windows xp installation disc....helpppppppppp, i need my lappy xxx
  • 174 Answers
PXE is the boot option from a bootable network card, so basically the BIOS isn't seeing any of your bootable drives and going trying to PXE-boot off your network. Check the boot options in your BIOS and make sure your drives are detected by the BIOS. If they are not listed, then the drive has likely gone bad.
Posted on May 06, 2010
Error message on dv 1000 pxe-mof and pxe-e61
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Apr 17, 2013 | HP Pavilion dv1000 Notebook
Display PXE-E61: Media Failure, Check Cable PXE-MOF: Exiting Intel Boot Agent Will not boot to windows. I boot from the hard drive and still get an error
Sep 25, 2012 | Gateway MX8741 Notebook
Pxe-e61: media test failure, check cable
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Next - to check if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an USB mass storage device and you cannot open the various folders and files on this drive, then this confirms the hard drive is faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 22, 2012 | HP Compaq Presario R4000 Notebook
My hp nx9030 keep rebooting itself with the message, PXE E61 media test failure check cable, PXE -MOF EXITING PXE ROM.what can i do
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Aug 26, 2011 | HP Compaq nx9030 Notebook
I have a problem geting my recovery disc to work in my compaq presario 2200 laptop, as i have just installed a new harddrive iam getting a PXE-E61: Media test failure and PXE-M0F Exiting PXE-ROM. ldygolfer
You need to change the boot order in the bios.
When you start the computer screen should prompt you at the bottom with something like:
F2 or F10 to enter setup.
Once you're in the bios, change the boot order to cd / dvd first.
Right now it's trying to boot through the network, that's why you're getting that message.
Let me know if you need any more help.
Best of Luck!
Feb 24, 2009 | HP Compaq Presario 2200 Notebook
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
May 11, 2008 | Computers & Internet
HP Compaq 6720s  PC Notebook Logo
220 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
