Question about JBL LC-S1200w Car Speaker
My jbl lc-s1200w has a little hole in the flex ring right on the edge how do i fix it
    Guru:
  • 256 Answers
Tak a little black silicone sealant and dont play for 24 hours
Posted on Jun 08, 2010
How to fix a deadbolt lock that does not retract fully so door unlocks to open
You have to move the lock covering the big hole back toward hinge side by loosing screws and moving to the side till the deadbolt moves back all the way flush. Some deadbolts have a little indent ring to go inside the hole to hold it in position, that makes it harder to move whole thing back. Other brands that indent ring an is only option that you don't have to use. Maybe someone installing didn't put hole in right place, if it's too far off the lock when flush may expose the hole some. Then new door or creative fix to fill gap.
Apr 10, 2016 | Deadbolt Locks & Locksmithing
1990 7.3 idi auto non turbo fly wheel removal a replacement
An automatic doesn't have a flywheel, it has a flex plate instead. The torque converter makes it act a lot like a flywheel, though.
But... you're probably talking about the flex plate or the ring gear around its edge. This is going to require removing the engine from the vehicle - there's no other possible way to get the flex plate out.
Once the engine is sitting on the shop floor, it's a simple job to replace the flex plate - first you unbolt the torque converter and set it aside, then you unbolt the flex plate from the crankshaft. Bolt the new flex plate onto the crankshaft, bolt the torque converter to the new flex plate, and put the engine back into the vehicle.
Jul 30, 2014 | Cars & Trucks
I CANNOT BE HEARD BY EITHER CALLER OR WHEN I RING
Hi,What causes phones not to ring out is when the ringer that makes you hear a tone when someone calls is damaged and does not work properly again.
The ringer is located inside the phone.You can get access into the phone by unscrewing the phone with a phone screw. It a little bit technical when unscrewing the phone.Just be careful not to damage the phone.
How to unscrew the phone.
Remove the back cover of the phone where the battery is,
then remove also the battery, at the edge you will see where the screw are located.(look closely).
After unscrewing,the screws, Open from the size of the phone,you will see where the ringer is located. It's usually round in nature. Remove and cover up the phone. (you can get a replacement ringer from any phone repair and sale of part store around you.
Ones your through with the ringer , 'wa la' Your done..
Note:if you can't loose the phone, in other not to cause damage to the phone,please contact a skill full personnel for assistance.
Most times, the flex of the phone make the phone not to ringout, because the ringer is connected to the flex, somehow..
Hi, no need to get a new phone, It can be fixed.There is a common fault for all Samsung cell phones. there is a thread like object inside the phone called a flex that controls the functions on the keys on a cell phone when it's gets damaged, it makes the keys to malfunction. You will need to replace the thread like object which is the flex inside the phone for the keys to function again.
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
Also it might be the screen of the phone. But in other to know if it's the screen, you will need to test a new flex.
You can get a replacement flex from any of the phone repair stores around you.
Before you replace it,you can also clean up the ringer ,there might be dirt stopping it from working properly.
Have a nice day.
Jun 15, 2011 | Samsung Cell Phones
Hello, I have a problem with the HUSQVARNA DESIGNER SE, in effect, the wire breaks every time when sewing. How do I fix this? thread tension has been tested several times but always the same problem. Thank...
If your thread is breaking while your doing embroidery, there could be a few different reasons. 1. The fabric in the hoop has to be as tight as a drum. When you "flick" it with your finger it should give you a poping type drum like sound. If the fabric can flex while the machine is sewing, you will break thread everytime. Also you need to be using the correct backing on the fabric. Your machine has a embroidery advisor that will aide you in choosing the right style of backing for the type of fabric your sewing.
Turn the machine off for the following:
2. Change your needle to a size 12 universal for most embroidery.
3. Inspect the inside hole of the foot for needle strikes. If the needle has struck the plastic "R" foot, your thread could be getting caught on it.
4.Remove the needle plate and inspect the hole for the same rough edges, there can't be any. Cut a strip of a metal sanding paper the size of the hole and floss the hole if needed to remove the burr. DO NOT ENLARGE THE HOLE. Simply smooth the rough edge. The hole size is critical for proper stitch formation. If the plate is damaged to the point metal is missing from inside the hole, buy a new plate.
5. Remove the bobbin case grey cover and the black bobbin case and inspect the metal round thread hook edge for roughness as well. Smoothing the hook is the same as the plate, you can't change the shape of the metal so don't go crazy sanding it. Just smooth the edge. The thread "races" around this area so smooth metal is a must.
I hope this helps, good luck!
Aug 18, 2009 | Husqvarna Sewing Machines
Lee foundation kit
there should be about 2-4 "slots" that can hold the ND filters. You have to add/screw on the additional side pieces that form the "slots" for the filter(s) to slide into, or add the pieces that make the slots wide enough for the filters. The Filter holder is NOT designed to hold gelatin filters, (the soft, very thin ones that flex when you hold them by the edges. ) only resin or glass filters, such as those made by Calumet, Sinar, Lee, etc. Also, you'll need to experiment a little with the tension of the screws to allow the filters to fit.
Feb 11, 2009 | Lee Foundation Kit Standard 4x4" Filter...
HP Deskjet 5150 - top cover open
I had the same problem, and the cause turned out to be the cover switch not being fully pushed in. On the underside right edge of the top cover, there's a little triangular protrusion that pushes down a black rectangular button (the cover switch) when the cover is closed. The problem occurs because the flimsy top cover is made of plastic and flexes slightly when you close it. This means that sometimes, the right edge of the cover won't seat properly even though it appears as if the cover is closed all the way. When this happens, the triangular protrusion isn't fully pressing the switch down.
To test if this is this is happening, send a print job to the printer and wait for the "top cover is open" error message to appear. Next, open the top cover door and locate the cover switch. It's a little black button in a rectangular hole at the right edge of the doorway near the ink cartridges. Take a pen or a car key and use it to push the cover switch down. You can also use your fingertip to do this if it's skinny enough. If you keep the cover switch pressed down, the power button should start blinking to indicate a print job is coming through. If the print job actually starts printing, then you know the problem was the cover switch.
In my case, all I had to do the fix the problem was close the cover and make sure it was fully seated by firmly pressing down the right edge of the cover until I heard a plasticky "click" noise. After that, the problem went away.
Hope this helps.
Jul 23, 2008 | HP DeskJet 5150 InkJet Printer
JBL spot series speaker not working.
I know this is old but just incase anyone has the same problem. Its proabably the connection from back panel to the internal amp (Inside the sub enclosure). The ribbon cable has the + for the left speaker right at the edge with quite a bit of tension. Over time and with the vibrations from the sub this will bend/pull out slightly and needs to be pushed back on and some hot glue put around the connection to hold it in place.
Thats how I fixed mine anyway.
Jul 12, 2008 | JBL Spyro Computer Speakers
6x9s in a clio
forget it...
buy some speaker cable & run them from the head unit to the boot.
from the back of the stereo connect as follows:
Rear Left
green + to Big Spade on speaker
green/black - to Small Spade on speaker
Rear Right
purple + to Big Spade on speaker
purple/black - to Small Spade on speaker
Dec 04, 2007 | JBL LC-S960 Car Speaker
JBL LC-S1200w Car Speaker Logo
65 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
