Question about Garmin nuvi 205 GPS Receiver
No Detailed Maps Found That Support The Nuvi
Attempted to update lost all maps
  • Anonymous Mar 29, 2014
    Detailed map of portugal
  • 67 Answers
Run through the entire update process again and that should solve your problem
Posted on May 05, 2010
Nuvi 50lm can't find maps
There are two different things to try.
1. Do a hard reset, that should restore the software and maps to their base condition.
2. Run Garmin Express and apply any updates it shows.
http://www.resettoo.com/hard-reset-garmin-nuvi-50lm
Aug 22, 2017 | Garmin Nuvi 50Lm - Gps Receiver
Hi, I have a Nuvi 255 (205 series) gps, three years old. Last week the screen went blank, came back grey with 'crosshairs' and a black dot in the middle indicating 'press here'. I did so and the dot moved...
Graham - what your describing sounds like you somehow managed to erase the street level maps and POIs in your Nuvi.
If you connect the GPS to the computer with your USB cable, you should at the contents of the Nuvi directories and find a file called GMAPPROM.IMG or GMAPSUPP.IMG. These are the street level map files. Generally, these are found in the root directory of the Nuvi - or if yours has / and you use a memory card slot for maps - find it in the /GARMIN directory. GMAPPROM.IMG is the name of the first map set and GMAPSUPP.IMG is the name of the supplementary or second map set (if you purchased & installed one). You will likely have only one of these files - and may be named either. The size of this file depends on the area and age of the map. Current maps of the entire US run over 1 GB in size. If you do not have any maps named GMAPPROM or GMAPSUPP, you will not see any street level maps.
Something happened to delete the maps. Garmin will probably NOT provide free replacement maps for you, unless under warranty. If the devices is trashing maps and other files, you probably want to replace the unit under warranty or not. Garmin will, upon return of your old Nuvi - replace it with a factory refurbished unit with the latest maps installed, for $79. You can take advantage of this service by following this link to Garmin Service.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 23, 2011 | Garmin nuvi 205 GPS Receiver
My garmin nuvi 200 it say no detailed maps
my garmin 200 nuvi say no detailed maps found that support routing
May 21, 2010 | Garmin nuvi 200 Car GPS Receiver
WHEN I POWER ON MY NUVI 255W IT SAYS NO DETAILED
sounds like the map folder in the gps software got corrupted. you will have to connect your device to your computer, get on the Garmin website, and let the garmin site update your device. Once updated, it will re-install the correct folders and maps to their proper place. the gps should work as before after that.
Mar 30, 2010 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi not picking up maps
Reset your unit and call Garmin. It might be a bad download.
Jun 22, 2009 | Garmin nuvi 200W GPS
Nuvi 255, no maps intstalled, shows unlocked in detailed info
This error is caused by a corrupt or missing map unlock code. Please email me @ sharcnet-usa@sharc.net and I will talk you through on how to fix the problem.
- Jim
SHARCNET-USA
Mar 20, 2009 | Garmin nuvi 200W GPS Receiver
No detailed maps found to support routing
Have you tried updating the unit at Garmin's Website?
Let me know if you need help, I can get you the right web-link if needed.
Benjamin
Feb 28, 2009 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Contact Garmins Tech support hot Line they will walk you through the process and if they can't fix it over the phone they will send you a disk that will completely fix the "NO detailed maps found that support routing" I have contacted them with the same problem and the disc was free of charge.
Jan 01, 2009 | Garmin nuvi 200W GPS Receiver
Updating maps
Press the power bar in the upper right c orner for 10 sec. and You will go into servicemood. Ther You can reset and run memorytests, Otherwise Use the lttle pihole under the tape on the bottom side
Aug 31, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 205 GPS Receiver Logo
102 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
