Panasonic Viera TH-50PX80U Plasma TV Logo
Posted on May 05, 2010
TV won't pick up DVD or Direct TV Receiver
Came back home after being out of town for a few days. I know we had bad storms and the power went out while I was gone. All other tv's in house with direct tv work fine except for my good one?!
It does turn on but just fuzz and no sound.
Anonymous
Level 1:
New Friend:
  • Contributor 111 Answers
  • Posted on May 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
111
Questions
0
Helped
34374
Points
22
I am not sure what type of set you have, but if it is a newer one,then it should have a separate power switch on the back. I would try shutting it down for a few minutes and powering back up. It almost sounds like the tuner has gone. Are you getting any colors? or just gray snow?If you can see the menu at all, I would also try reset to factory defaults... good luck
Don't know how to program TV since went off during storm I have a 37" TV purchased at Future Shop in March. Can't seem to reprogram it as it went off after a storm. Tried unplugging the...
Tries go into tv menu goto SETUP.Go down to Ch.enter pick AIR and enter to scanning.After finish scanning should have all the free DTV broacasting channels again.
Hitachi 46w500 went off tonight during storms, low voltage, wont turn back on
There might be a failure on the power supply or horizontal section of the TV even if you see some light inside the TV. Some of the voltages could be missing and that is why the TV fails to power up.
If you know how to use a multimeter, you could check all the fuses from your power supply.
Unplug your TV from the main AC line if you intend to do it yourself.
You will know how much you can do or it might safer to contact a tech.
Let me know if you need further assistance
Onkyo tx-sr604 help
You said you tried hooking the HDMI up directly from the TV to each component, and that worked. How is it usually hooked up - through some kind of switch? I'm not completely understanding your setup here.
1helpful
No longer getting video feed through Home Theatre receiver
HDMI ports 5 and 6 on the back of tv no longer are working. (We had a series of thunder storms so don't know if that is how they got damaged or if it was something else) but moved HDMI input cable to HDMI port 4 on tv and everything is working again. Service call placed for warranty service on tv to repair bad ports.
TV won't work after storm
ok lets try this hit the power button on the DVD player some go into stand by mode and when power is interrupted you have to push the button manually also reset the surge protector next get a lamp that you know works and unplug the tv and plug the lamp into the socket where the TV was plugged into turn on the lamp, does it turn on? yes then something wrong with TV again may have been in stand by mode plug back in and try pushing the power switch on make sure the TV if it has a remote is on the right im put to get a picture say like a satellite or cable or DVD player. hope this helps.
Lightning storm blew out my SonyDAV-770, I think.
Power supply area could be damaged so getting an estimate of repair from qualified technician will help to decide, what to do :D
1helpful
Hitachi 50vs69a
have power supply normally the voltage regulator gose bad normally start str f668b
2answers
New home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
No sound
you may have a blown fuse. check that first. Very if it still has a power.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
