Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
RANGE DOOR IS LOCKED AND NOT ABLE TO OPEN. KENMORE ELECTRIC RANGE. i have depressed the cancel button, no response
  • 523 Answers
Try puting it into self clean then cancle it see if that corks or use a clothes hanger to open it
Posted on May 06, 2010
Self cleaning range - door is locked, food inside, and self clean malfunction
Here are a couple of remedies that may work:
1. Disrupt the power to the stove for at least 5 minutes. If the clean cycle has been on to heat the oven at all, wait until you are certain it is completely cooled down. Patience is a virtue. There should be no lights on the panel. This resets the stove and stove errors the majority of times. I usually pull the plug at the rear of the stove. It gives me a chance to clean the floor while waiting. Re-power and determine if the if the clean cycle cancels. If not, go to 2.
2. Push the door in and press "Cancel". There is a push button switch (not visible when the door is closed) that is also a part of the self clean circuit. This switch may not be fully depressed. If it does not cancel, press the "Bake" button and press "Start". If it continues on the clean cycle, allow it to run for approx. 5 minutes and then enter "Cancel". If it does not cancel, retry the #1 waiting longer than 5 minutes and repeat #2 sequence.
3. The door can not be disassembled when it is locked closed. The lock mechanism is at the top of the door in the center and approx. 2" down.. The latch operates from left (open) to right (lock). It may be possible to get a slim jim type device to disengage the latch. A piece of scrap spring steel pallet banding may work for this You may have to depress the "Cancel" while doing this/. Hopefully, your range cooperates and you do not have to try 3.
Let us know if any of these work for you.
May 29, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Hi, The door of the oven of my kenmore cooker locked itself and the code 'F9' flashes alternatively with the code 'dr' can you please give me some help to fix this issue? Thanks
Hi, the F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Oct 08, 2010 | Kenmore 47732 / 47734 / 47739 Electric...
40494 / 40495 / 40499 Electric Single Oven: have a kenmore self cleaning electric range it was...
The F9 code indicates there is a problem with the door lock.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Door lock engaged with door open
push the clear/off button for about 3-5 seconds this should release the latch
Jan 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Cleaning Kenmore double ovens back to back. During second cleaning got F9 code and the bottom oven is locked. Cleared the F9 will the bottom oven unlock when it cools down?
Jan 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Pushed the clean button, the oven locked, and the screen started beeping and flashing f9 or f7. I hit cancel, and the oven is still locked and the clean button is sill flashing.... It has been 10 hrs!
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%^%$
Jun 21, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore oven 41775790 locked door
after self cleaning with the racks still in oven, i cannot get the oven door open, locked down, does this have something to do with the racks left in oven during cleaning. what do i need to do
Jan 17, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven door on lock
is the light oven on??? can you see the switch/button that the door would hit against to turn light off?? if so depress button so the lifht goes off, and start a clean cycle.This should make the lock mechanism engage fully. then cancel cycle and should fully disengage lock/latch (you need to depress light switch to trick unit into thinkin the door is closed)
Mar 08, 2008 | Kenmore 30169 Electric Single Oven
Door won't open
Try holding the Off/Cancel button.
Apr 12, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
160 people viewed this question
Top Kenmore Ovens Experts
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
