Question about Gateway MX8738 Notebook
The laptop will not power on and has a fully charged battery. The power on button will not light when pushed. When plugged in the led light on the front edge of the laptop should start out pink then turn blue when the battery is at full charge. This doesn't happen. The dc power jack was removed and a couple of tests were run. The center pin hole in the motherboard to the other 5 ground holes in the moyher board all show continuety with an ohm meter. Can you help determine where the short is on the mother board?
  • 748 Answers
Hi
I presume you checked the DC power supply. Don't use a generic power supply on this model, because that will cause alot of different symptoms. I use the exact same model on service calls. A further way to test the mother board is to remove the CPU and memory. Carefully provide power and look for lights. If none, my next step would be to refloat the video chip. This requires special equipment. A replacement mother board without processor on eBay is $49.00 so it might be time to consider that. Good luck
Posted on May 05, 2010
Testimonial: "thank for the tip. I will try your sugestions"
I have a Sony Vaio laptop, model PCG-384L. It will not power up. My wife indicated that she push some button that lock the power. Can seem to find the button that controls or locks the power button. ...
Typically that flashing light means low battery. Which makes sense, as you probably have an issue with the AC Adapter that you plug into the computer to charge it, or the DC Jack that this adapter plugs into on the laptop. Either of these things will cause your computer to not charge the battery, and if there isn't enough power it won't turn on.
Aug 10, 2010 | Sony VAIO Notebook
Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Jul 06, 2010 | Motion Computing C5 Tablet PC
Won't turn on. Battery is plugged in and lit. n
Try removing your battery pack. Then connect the power adaptor (even without the battery) and connect is directly to the power outlet. If it powers up, then the battery pack might be defective or totally drained.
If the battery is just totally drained, simply place the battery to the laptop. Do not turn the laptop on. Plug the power adaptor to the laptop and plug it to the power source. If you see that the charging LED is blinking in your laptop, then just leave it charging up to 5 to 8 hours.
Never use a laptop on battery mode while it is plugged in to a power source. This is the number 1 reason why laptop batteries don't last longer.
Jun 06, 2010 | Sony VAIO Notebook
Lenovo Y530 T 3200 3GHZ 4G Laptop not charging battery when plugged into outlet;also does not work on battery alone even though it is charged to 85%
Try to perfrom power drain. You must first turn off the computer. Take out the battery and unplug the power adapter. Press and hold the power button for 30 secs. Put the batter back in, plug in the power adapter and power ip the computer then observe.
Let me know if same issue will happen.
May 11, 2010 | Lenovo IdeaPad Y530-3231U Laptop Computer...
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
My dell D810 won't power up. After pushing the power button, one LED light comes on. About 5 seconds later, that LED light goes off. I swapped power adapters and symptoms remain the same. The battery is...
Please try the following troubleshooting steps:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Connect the charger (don't connect the battery yet) and try to start by pressing the power button.
Let me know if everything remain same.
Feb 18, 2010 | Dell Latitude D810 Notebook
0190 critical low battery error
lights ambar blinking 5 times, stop, and again..
I was pushing the power button at the same time with thinkpad button, and fast press F1 key.
I only needed 3 times and it fixed problem.
Right now laptop remaining in bios mode, charging battery normally.
good luck!
Nov 24, 2009 | IBM ThinkPad T20 2647 Notebook
I am trying to figure out what the buttons on the underneath of my laptop are for, they show a battery sign and mine only stays charged for an hour?
That battery LED shows up when you are connected to AC power. When the battery is charging, the light is up. However, when it is fully charged, it will change color or disappear or does not light. But I am begging you to not use your laptop always with the AC power so as not to destroy your battery. When you are at home, plug your laptop to charge but dont open it. When it is fully charged, remove the battery and turn it on while the battery is out. It is the safest way to conserve and lengthen the life of your battery. Use only your battery when you are in places where there is no power outlet or when you are on the go.
Regards!
Sep 25, 2009 | Toshiba Satellite A135-S2276 Notebook
HP altec lansing Pavillon DV 6700 not powering
I am sorry to say that this is likely to be motherboard damage. The only other possibility is the the Power jack on the laptop itself is loose or shorted.
Either way.. You need a qualified repair.
The safe bet is a new motherboard.
sincerely,
Sagacious1
Aug 07, 2009 | Computers & Internet
Does not power up.
Remove the battery and try to turn on the laptop without the cord plugged in to allow the device to completely discharge. Put the battery back in and hold the power button in for 45 seconds, the lights should flash and then turn the laptop on normally.
This always works for my laptop.
Jun 26, 2009 | Computers & Internet
Gateway MX8738 Notebook Logo
273 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
